e39a
- 71
- 0
- Oct 11, 2008
san diego,
California
hey my name is george im new here.>>>>anyway im having trouble with this car hope fully someone can help me >>the car is a 96 eclipse gst and i put a 1g engine as far as the cam angle im using the 1g cas with the harness to connect the 2g cas and crank angle also i alredy change the plug wires 1,3 2,4 also i did the wire swap for the injectors at the ecu pins>>>>the car turns on and dies right away sometimes it will idle bad like is miss firing >>>theres no codes at all>>>i already change different cam angle sensor igniters coils this is not my first conversion but is the first one to give me problem i bent dealing with this for over almost two months>>>i would like someone if is possible to come look at the car cause im 95% that i did everything right im located in san diego
THANKS
THANKS
