1g Body panels?
PM me if you need 1G body panels. i don't think they can be gotten from dealers anymore. only aftermarket suppliers such as body supply stores if i'm not mistaken. and aftermarket body parts usually suck compared to OEM
I'm not sure if you can get them from a dealer either. If you can, I am sure they will be expensive. If you need anything I would also be able to get you ANYTHING you need, Just send me a pm and let me know what you are looking for.
I need two new rear quarters and a new drivers side front quarter. they are pretty shot... but if it would be done for minimal amount i would like to do new panels all the way around.
If you need rear quarter pannels- you need to CUT them off of an old car and tacked onto your car. Get a sawzaw and head out to a junk yard.
cut them off ????? :confused: you mean they are not just replaceable?! OMG
the reason they need replacing is they seem awfully thin in the wheel well area as well as they are rusting throughly. (bubbling under the paint, flaking a bit on the well.) but cutting them off sounds like a shit load of work
yes, the rear panels will have to be cut from one car, then welded onto your car. there is ALOT of work involved since they need to be cut nearly the same way so they fit. not an easy task...
