1G AWD with KYB AGX's and Pro-Kits, will I need a Front or Rear Camber Kit?
BLT_GSX
Aug 16, 2004
Down South, Louisiana
Looking at installing KYB AGXs and Eibach Pro-Kits on my 1G AWD, will a front or rear camber kit be needed? I know on the 2G AWD it can go either way, I ended up needing both Front and Rear Camber Kits with the Pro-Kits.
Thanks for any help
frank
I also agree, the drop with prokits is minimal, it's more for performance than looks.
I have AGX/Prokit, and I needed to add a rear camber adjuster to prevent it from being too much negative. I also have fronts, which are maxed out to get as much negative as it can get.
