1g 7bolt vs. 2g 7bolt
All_Boost16G
212
Oct 22, 2007
Sheldahl, Iowa
Wondering what the difference is in the blocks. I have a 2g 7bolt motor, but got a sweet deal on a already machined block from a 1g 7bolt. Just want to know if everything bolts onto it like a 2g 7bolt, or what needs to be switched.
Pretty much my options are open on the head. I just want to make sure the block will work with the tranny, and motor mounts or will I have to use different mounts and a tranny.
I have a 1g head on my car. I have 2g motor mounts holding everything in.
As for which head, the 1g has larger port sizes, but the 2g supposedly has better flow patterns. There are a few threads on here debating which head to use. My guess is that unless you're going for really big numbers, either head will work fine and you won't notice much of a difference. If you want to use the 1g head, check out this site:
RRE's Eclipse 2g Turbo to 1g Head Swap Tips
Okay, I started to think about this. There is really no way to use the 1g motor mounts, since the 2g has all the mounts on the transmission.
