6bot vs 7bolt
Jon_0_3
164
Jul 5, 2004
Hartford, Wisconsin
hey ppl wondering what the BIG differences between the 6bolt and 7bolts are. also what are the pros and cons of both motors there are a bunch of ppl telling me the 7bolts are better and i just want some more info to go into battle with. thanks:mad:
m3th0d said:
Hi guys,
I own 2g 7 bolt and let me tell you, it has over 150,000 miles on it. I doubt it will ever be a problem in the future. If anything, I think my engine will go out and I will never expirience crankwalk.
LOL... this must be a really "inexpirienced" (cough cough) DSMER, dont ever say a 7bolt will never crankwalk.... your just a complete moron, and dont ever say any DSM motor will have a problem in the future, thats like saying "Ive had sexual intercourse with 100's of hookers and i doubt i have any kind of STD, nor in the future will i get any STD's while sleeping with random sex slaves.
plainly your a confused 2g driver.
Pure92TSi said:
I don't know who is telling you that but they are wrong. The 7 bolts have a factory defect and have a tendency to "crankwalk." The 6 bolt motors are much stronger. This is why a lot of 2g guys do the 6 bolt swap. Your car is a 92 so it's possible that you have a 6 bolt motor. Check the build date in the door jam of your driver's door. If your car was built before 5/92 (i think) then it is a 6 bolt. If built after it's a 7 bolt. If you do have a 6 bolt, like I do, then your golden because you also have a stronger 4 bolt rear end.
Who told you that the 7 bolts have a "factory defect"? Just because the 7-bolts are more prone to crank walk than the 6-bolts does not mean that the 7-bolts have a deffect. It just means the 6-bolts will hardly ever crank walk.
Th dates you've mentioned is good info:thumb:
Everyone is missing the real advantages of the 6-bolt engine:
Fatter rods
Wider non-torque-to-yield head studs
This allows over 500whp on a daily driver.
Also 6-bolts and pre-1995 7-bolts have lower compression which lets us get away with more boost. More boost is more airflow. More airflow = more power. I'm not saying thi s is an advantage. But most find it so (including shep).
The main reason the 2g 7 bolt engines Some times tend to crankwalk is because the different oiling system for the pistons.
In my view the best one is the 1g 7 bolt with is a totally different engine then the 2g 7 bolt. the 1g 7 bolt has the awesome block girdle and is a stronger block,.
But w.e the whole crank walk issue is hugly overrated. Yes it does happen somtimes but any engine can. even the 6 bolts. but since they have a better oiling system for the pistons they usually dont. but they share the same system as the 1g 7 bolts.
Do you mean the actual block? or the internals? Either way, ALL dsm blocks have the same durability. 2g blocks have gone jsut as far as 1Gb 7-bolts. They both have the small rods. All teh reliability is the same between the two.
And only 6-bolt blocks came with the stronger internals. 6-bolt blocks (meaning the internals) are stronger than 7-bolt 1Gb blocks (meaning the internals).
Look if you want to troll, this aint the forums to do so. If you read carefuly my previous post, you noticed I said " I doubt it will ever be a problem in the future. If anything, I think my engine will go out and I will never expirience crankwalk ".
Meaning, the engine will die soon to even have a chance to crankwalk.
