Resolved 1G 2G valve cover on a 1G
Solution
Yes, the 2G 4G63 rocker cover is interchangeable. Make sure you use new gaskets and seals and don't over tighten it. The spec for the bolts is in inch pounds. There are threads here on when the RTV goes in the corners and the torque specs.
Solution
    • Sdcryan1
