Sold 1g/2g parts best offers
ohlegend
581
43
Apr 2, 2012
Pemberville, Ohio
Feel free to make offers - I am regretfully selling my car and I want to give my stash up to the community. You have all been so helpful. Thank you!
6 bolt front case gasket set with head gasket
Stock 2G Intake manifold
New BPR8ES x4
6 bolt timing plate
Boost solenoid
EGR solenoid (I think)
Oil Pressure sensor
Good thermostat
Back up light housing
Front license plate brackets
Crank sensor
IAC valve
New PTU bracket
Power steering caps x2
Brake fluid reservoir cap
6 bolt throttle position sensor
7 bolt throttle position sensor
idler pulley
Evo 3 hard vacuum lines for Evo3 intake manifold
Good coil pack
6 bolt oil return
2G throttle body elbow
oil pump gear
Haynes manual
Cam gears
2G Stock intake cam
Balance shaft sprocket x2
Harmonic balancer
Evo 8 valve springs (minimum 25$)
1G piston - stock
New Pacesetter sparkplug wires
NEW ExtremePSI exhaust manifold stud and nut kit (min 25$)
Relays
Biss screw
Spark plug cover bolts
Fuel rail spacer
Turn signal bulbs
PCV x2
2G auto flywheel bolts x7
check valve
temp sensor x2
ExtremePSI gasket for evo3 16g
2G tan interior visor hook
2G knock sensor - SOLD
MAP sensor x3 (1 with pigtail)
2G throttle position sensor with pigtail
oil level sensor
Temp sensor
2 sets of valve seals
2 sets throttle body metal gaskets
1 set of standard 6bolt piston rings (ITM)
Crank bolt
2 Newer Denso front O2 sensors
