1999 vacuum line removal..diffrent from 97 down?
blaise2gst
54
May 25, 2005
stephenson, Virginia
So ive been searching for this for about an hour and i can't find anything on it.. all i know is it doesn't have a evaps or one of those thype things,or a charcoal canister.. then there's a larger hose one the intake manifold that went down and hooked up to one of the valve's.. it's hard to explain...so if anyone that know's anything about the 99 vacuum emision's system id appreciate the help..
Does the end of the hose have a circular section on the end of it? What spot does it come off the Im, or is it coming off the fuel rail?
Dustin
Same here, I'd look at my brother's 97 and it differs. Looks like we have 2 canister vs 97 and down with 3. At first I though that the dealership jacked my canister and the P vaccuum hose that comes out of the throttle body. Can you check to see if your car is missing that piece, because I'm missing that as well. At the throttle body there should be 2-3 vacuum line that comes out label P E A. Don't really know what these stand for need to look it up.
