2G 1998 Mitsubishi Eclipse and Spyder Factory Service Manual Volume 2 - including Electrical
1998 Mitsubishi Eclipse and Spyder Factory Service Manual Volume 2​
The binding on my copy was falling apart so I decided to end the fight and scan in all the pages. The big difference here - I scanned in the complete second book by section so you no longer need to download 2000+ pages of a manual to find that 3 or 4 pages of the Tire and Wheel section, for example. Each post below contains a PDF for the specified section, in order. There is a bit of a bonus going along with the Circuit Diagrams, hopefully that comes in handy!
Here is the table of contents for Volume 2 so you know what the rest of the posts hold. Also, attached here, is a PDF version of the table of contents along with the Index pages for the manual, generally found at the end of the book.
Automatic Transaxle - F4A23
Automatic Transaxle - F4A33 & W4A33
Automatic Transaxle - F4AC1
Propeller Shaft
Front Axle
Rear Axle
Wheel and Tire
Power Plant Mount
Front Suspension
Rear Suspension
Service Brakes
Parking Brakes
Steering
Body
Exterior
Interior and Supplemental Restraint System (SRS)
Chassis Electrical
Heating, Air Conditioning, and Ventilation (HVAC)
Component Locations
Configuration Diagrams
Circuit Diagrams
Automatic Transaxle (Overhaul) Section 23 - F4A23
Automatic Transaxle (Overhaul) Section 23 - F4A33 and W4A33
Automatic Transaxle (Overhaul) Section 23 - F4AC1
Propeller Shaft Section 25
Front Axle Section 26
Rear Axle Section 27
Wheel and Tire Section 31
Power Plant Mount Section 32
Front Suspension Section 33
Rear Suspension Section 34
Service Brakes Section 35
Parking Brakes Section 36
Steering Section 37
Exterior Section 51
Interior and Supplemental Restraint System (SRS) Section 52
Chassis Electrical Section 54
Heating, Air Conditioning, and Ventilation / HVAC Section 55
Component Locations Section 70
Configuration Diagrams Section 80
Circuit Diagrams Section 90 -- too large for upload, which I was afraid of when I started this. :coy:
See Dropbox link:
Dropbox - 1998 Mitsubishi Eclipse & Spyder Electrical Diagrams
The file attached to this post is the "extra" - an index of the electrical connectors in this section. So, using the connector notation from the configuration diagram, this document lists every page in the circuit diagrams that connector is actually found. It makes tracing wires through nearly 300 pages much quicker and easier.
