1998 GSX Solenoids
PrimerPLus
1,160
20
Jul 28, 2011
Tokyo, Asia
I am looking for some locations of solenoids.
I can only visually see my EGR Solenoid, and my Fuel Pressure Solenoid.
I also can see my EVAP Vent solenoid.
It reads 19 ohms, but if I breathe into either port it just blows air right through. I dont know if it's working or not.
I need to know if there are any others?
I am not sure if evap vent solenoid and evap purge solenoid are the same.
I have the code P0443 EVAP Emission control system purge valve.
I have replaced the Valve, Purge Control ( MD011227)
but this did not change nothing.
On this page you can see there are 3 solenoids. I am missing or can not find its location of the one marked with a yellow line.
Solenoids.
I thought that this was it but it looks nothing like that one.
The one circled in green is the same one as a picture I already posted just above.
It would be helpful if anyone could find or take pictures of theirs of the locations so I could find them. It should be off a 1998 or 1999. The layouts of the earlier ones are different I think. :thumb:
They all should be in here: http://www.dsmtuners.com/forums/art...047-2g-engine-bay-electrical-connections.html
Now that I think about it I went through this exact same problem a few years ago and if memory serves me correct it was this sensor underneath the back seat drivers side (opposite of the fuel pump which is located on the passenger side). I've long since switched to an EVO VIII ECU so I no longer have to deal with this.
The CEL is not what bothers me. I can turn it off via DSMLINK. What bothers me is that it is broken LOL.
Looking at past pics I took of my GSX bay when it still had all the EGR stuff like you I didn't have the purge control solenoid valve that is marked with the yellow arrow. However I did have the EVAP Emission Purge Control Solenoid Valve which is #35 in the above link I posted. It may have something to do with on '98-'99's the charcoal canister is located in front of the front driver's side wheel as where '97's and prior the charcoal canister is located under the battery.
Just wanted to say thanks guys. I found it! You are right it is picture #35 from the link that finesse49ers linked. I am in the middle of changing it. I will post back if the cel is gone.
