420A 1998 eclipse rs no fuel
damonmlime
Jul 26, 2006
morgantown, West Virginia
Hi, my girlfriend has a 98 eclipse rs automatic. She parked it for about a week. When she tried to start it after that, it fired up for about 20 seconds then died. The first thing I did was check for spark. Plenty of spark but no fuel. I replaced the fuel pump but I'm still not getting any fuel. The only way it will run is if you spray a little starting fluid into the throttle body. Has anyone else had this problem? Thanks, Damon
So, you checked for fuel pressure and their was no fuel.. you tried the fuel filter, and the lines to see any leaks or bends? Fuel pump turning on?
I'm not getting any fuel. The fuel pump wont even prime. I'm gonna take a look at the mfi fuse again but I'm pretty sure that it's not blown. I've already changed out the fuel pump so I'm sure thats not the problem.
Might want to consider double checking the connections for the pump, and if the pump itself is receiving power/signal.
Did you change out the fuel filter on the bottom of the fuel pump when you changed it out? If you didn't it can result in premature fuel pump failure.
I went exactly by the instructions on the fuel pump. I think maybe it could be the crank angle sensor. Has anyone had experience with this on a dsm? Can someone point me in the direction as to where the sensor is and how I can tell if it's bad or not? Thanks, Damon
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
