1997 Gst Crank
Mrevolution
Nov 20, 2011
Spokane Valley, Washington
hello i am a noob in DSMs. I have a question
i took apart my engine and i noticed the bearing are spun
and the crank is in bad shape. Is it better for me too resurface
the crank about or to get a new crank altogether ?
or maybe go with a 6bolt swap but its more expensive this way?
If it did crankwalk rebuilding all that stuff is going to be expensive and people say here that there is a high chance it will walk again. Look around for a used bottom end. Shit I got a long block with accesories on craigslist for 400$ and the engine only had 40kmiles on it.:rocks:
can u send me a link to the craigslist page
If you can get by with only taking .010 off the crank than i would just have it turned. Did is spin a rod bearing or main bearing?
It would be better to get a new crank. Although, if you have the money a new motor would be best.
The issue with a 6-bolt swap is that it can still crankwalk, any engine can, and not only the money to perform the swap, the time needed as well would bother me(I'm impatient :p) I would just pick up a new crank/shortblock rebuild kit. If your engine has quite a few miles, crankwalk was not an issue.
