92AWDTalonTSI
- 334
- 8
- Jun 2, 2010
Somonauk,
Illinois
With the Factory MOD 2012 coming up on the 22nd, We've got to get things moving.
At the moment we have a Evo 8 Dash going in.
Coming up are the Black AEM Tru-Time Cam Gears, Zakk Lee clear timing belt cover, Down pipe cut out and hopefully a tune at Boostin Performance in Addison Illinois. Just in time for MOD? Hope so.
Here I will be posting the progress and wiring schematics for the Dash install.
Set the dash in for trimming:
A 2003 Evo instrument panel diagram:
1992 Eagle Talon TSi instrument panel diagram:
The Rheostat is connected the exact same way utilizing the same colored wires. Green with a White stripe, Black and Black with a Yellow stripe.
The hazard switch is a bit different. I'm thinking using the stock switch and using a relay setup to toggle it on and off by piggy backing it. Or modifying the switch to fit the evo dash and use the evo button it's self. The stock evo switch is momentary where the dsm one is not. Help me decideeeee.
Text based schematics
Code:
Mitsubishi Lancer Evolution VIII
C-106 (White Connector)
1 BLK...........Ground 3
2 BLK...........Ground 3
3 BLU/GRN.......Left Turn Signal (+)
4 RED/WHT.......High Beam (+)
5 BLK...........High Beam (-)
6
7 RED/BLK.......J/C 1 (+) (10AMP FUSED)
8 YEL...........Door (+)
Ignition
9 YEL/RED.......Charge (+)
10 GRN/WHT......Tarmac (-)
11 GRN..........ECU/Tach Input
12 WHT/BLK......Speedometer Input
13 GRN/ORG......ABS
14 PNK..........Gravel (-)
15 VLT..........Snow (-)
16
17 WHT/BLU......Check Engine (-)
18 WHT..........Oil (-)
19 RED..........Charge (-)
20 BLU..........Fog (+)
21
C-108 (Blue Connector)
31
32 BRN..........Brake (-)
33 VLT..........Water Spray (-)
34 BLU..........Door (-)
35 RED..........Seat Belt (-)
36 GRN/YEL......Air Bag (-)
37 BLU/GRN......Brake (+)
Positive Lead
38 GRY..........General (+)
39
Negative Lead/Rheostat
40 BLK/YEL......J/C 3 (-)
41
42
43
44
45
46
47
48 BLK..........(-)
Fog (-)
Turn Signal (-)
49 PNK..........Right Turn Signal (+)
50 YEL..........Water Temp Input
51 GRN..........Fuel Gauge Input
Fog Light Switch
3 - Black Yellow - From Rheostat
4 - Green White + From fuse box 7.5a
Hazard Warning Light Switch
3 - Green White + From fuse box 7.5a
4 - Black Yellow - From Rheostat
Code:
1992 Eagle Talon Tsi
D04
1 BLK...........GND (-)
2 BLK...........(Connected to 11 for TACH GND)
3 GRN/BLU.......Left turn (+)
4 BLK/YEL.......Rheostat pin 2
5 GRN/BLU.......Rheostat pin 4
6 BLK/RED.......Boost IN ~
7 BLU/BLK.......Cruise Control Light (+)
8 RED/GRN.......Check Engine (+)
9
10 YEL/GRN......Temperature IN ~
11 BLK..........Tach GND (-)
12 WHT..........Tach IN ~
13 YEL/BLK......Oil Pressure ~
14 BLK..........Ignition (+)
15 BLK/WHT......Charge Light (L Terminal) (+)
16 YEL..........Oil Light (+)
17 BLU/YEL......Coolant LVL switch (-)
D05
51 GRN..........Seat Belt (+)
52 YEL/BLK......Seat Belt (-)
53 GRN/BLK......BLANK (NORMALLY SECURITY LIGHT)
54 RED..........High Beams (-)
55 YEL/RED......High Beams (+)
56 GRN/YEL......Right Turn Signal (+)
57 YEL..........Fuel Level IN ~ (-)
58 GRN/RED......ABS Light (-)
59 YEL/WHT......Speed sensor ~
60 RED/GRN......OverDrive OFF (+)
61 RED/BLK......Door Light (+)
62 GRN/RED......Door Switch (-)
63 GRN/BLU......Economy Mode (+)
64 YEL/BLU......(LOW) Fuel Light (-)
65 BLK/WHT......Break Ignition (+)
66 YEL/GRN......Parking break/Brake Fluid LVL (-)
67 GRN/RED......Power Mode (+)
