defrag010
- 420
- 8
- Sep 24, 2004
n/a,
Alabama
OK. I have a 1990 tsi FWD that i'm building. I put my car together this weekend, and It's not getting any spark and the injectors aren't firing. I measured the coil pack connector, and the coil is getting power, but no pulse. I took the CAS off and spun it, but the injectors did not fire. The fuel rail is getting fuel, but it's not getting past the injectors.
I hooked my datalogger up, but it acts as if there is no ECU.
All of the fuses in the vehicle (under the hood and inside) are fine. The only thing I haven't checked is the ECU power wire because I don't have an ECU pinout. It could be possible that my ecu isn't getting power. I even went so far as to check the voltage on the wires After the fuseblock on the battery terminal. All three wires had power.
Could it have something to do with the MPI relay being messed up? The car has a new CAS, coil, and transistor. If it helps, The only dash lights that come on when I turn the car on are the Battery, Seatbelt, and Parthenon (coolant). I opened up the ECU, and it looks clean with no burnmarks or exploded caps. It smells pretty too. I was thinking about running a hot wire from a separate source to the ECU to see how the car would react if the ecu was getting 100% power, but I didn't have a pinout and I didnt' want to risk frying anything.
I don't have a spare 90 ecu to test out, and I have to get my car running by november or I will have to tow it to another garage.
Oh, it's also 100% stock electronics and engine.
Hope you can help.
Hope you can help.
i have the ECU pinout printed out ,but i just got to find the website where i got it from so i can send it to ya, i'll get back to ya as soon as i do thow
