1G [1990] How to unplug coil pack?
nelliott500
337
20
Mar 24, 2013
Oxford, Connecticut
I'm trying to do a compression test but I don't know how to unplug the coil pack. I'm following this thread to do the compression test and it mentions a clip on the connector but I don't see anything. I tried just pulling and wiggling it but it isn't budging. What do?
And just to clarify, this is the plug, correct?
That actually makes more sense considering the smaller thing is only one wire. Not being near my car right this second, I don't remember anything else really looking like it plugged into the coil pack.
Found a pic. Its not the plug circled, its the plug right on top. Black with red and yellow wires going in the back. Im pretty certain its the plug I suggested in my first reply.
Edit: Im certain. Pull the plug and crank the engine, bet you'll have no spark! :thumb:
Nah, just unplug the MPI fuse to keep the injectors from firing.
That's your big worry, not the spark plugs firing and those one can swing those away from the head.
Or, you can wrap each end of the plug with black tape-keep you from getting bit if you want to make it easy on yourself.
But undoing the plug for the coil isn't that all hard to do
If you do compression check with cylinders being filled with fuel by the injectors, that definitely will throw off a true compression reading.
Motor has 154k on it and is mostly stock.
#1: 140, 140, 190 (oil)
#2: 160, 155
#3: 160, 160
#4: 160, 160
Obviously #1 is worn out (assumed piston rings although oil test isn't 100%) but what do you guys think? #1 is still well above the service limit and the rest of the cylinders seem good to me.
Did you let the motor crank a few times to get the highest compression before you push the button on the side of the gauge to lock the needle?
Did you do numerous tests per cylinder to get your best reading?
Best to be sure.
No.1 is a little tired than the others, but really nothing to get all excited about.
I have one of those readings also and just going to let it go until I really need to do an overhaul. Why bust up the block to get my 20 lbs back in one cylinder where I might as well do the full overhaul when the money is right?
-Good luck - DSM
I let the motor crank for five revolutions for each reading and I did two tests per cylinder (three on #1 because of the oil test).
I'm not too worried about it. I know they're supposed to be as close as possible but #1 is still well above the service limit. Eventually I'll dig into it but that's (hopefully) way down the road yet.
