1990 c.o.p. connector help!
eclipse_16g
275
24
Oct 8, 2008
Connecticut
im putting my 90 motor into a 92 my c.o.p. setup has the connector for a 90 harness and wont fit this 92 harness. i have the harness out of my 90 to swap connectors, but the 92 is a 3 wire, and the 90 is a 4 wire..
any suggestions? this is a very expensive coil set i dont want to have to just throw it away for a stock coil pack.
90 c.o.p.side
92 wiring harness side
On the 92 side. The black and white is the power wire. The two yellows (yellow w/ black and yellow w/ green IIRC?) are from the ECU to fire each coil.
To be 100% sure of whats next, you need to see how the COP is wired, but I would guess:
- That the white wire won't be used.
- The thick black wire is the power = the black with white stripe on the 92 harness.
- The blue and black are coil wires, which would be connected to the two yellows.
You will need to figure out which yellow wire needs to go to which coil though. To figure it out, you need to look at the wiring of the COP.
Hope that helped some.
-Jeremy
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
