190lph limits
lq1driver
206
Dec 17, 2007
painesville, Ohio
hey im just finishing up my winter project and realized im still on my 190lph fuel pump. what i need to know is with my base fuel pressure being 43 psi with 25 lbs of boost on 750cc injectors will the 190lph be able to supply the fuel im lookin at 68psi under boost.
If you don't want to buy a higher flowing pump, than you may just have to see what your idc's are at the time, its hard to say, but will be cutting it close for sure
Fuel pump rewire for sure. I'm running a Denso 150 LPH with rewire on 660cc injectors with 44 lb/min of measured compressor flow. It was dicey a while back without the rewire but it holds fine now.
  • Wanted 6 bolt NT water pipe
    • chrisman287
