o0-TaLoNbOy-00o
- 57
- 0
- Oct 22, 2002
N-Dub,
will these rims fit 18x8 45 offset...im not good with any of this tire stuff
polonez said:no they wont.
i run 225/40/18
MCDGexx said:Eclipse 4x4 runs 18x8.5 rims. Dunno if thats what you mean.
dsm023 said:45 might be much without rolling your fenders! You can run up to 8.5 with the right offset and not rolling your fenders. +35
o0-TaLoNbOy-00o said:ok..does anyone have this size on there car rims now or has anyone tired this size?!
o0-TaLoNbOy-00o said:...im not good with any of this tire stuff
wret said:Apparently no one else around here is either. And no one reads any of the stuff in the tech articles and FAQ and hundreds of posts on wheel and tire fitment...
In case anyone read and believed the post above explaining offset, please forget it. It was completely wrong. A better term for offset is the German term 'Einpresstiefe' (ET)which translates as Insertion Depth. The higher the number, the more into the fender the tire will be positioned. As the number gets higher, you risk rubbing the tire on the rear steering knuckle that passed over the tire at about a 45° angle. As the offset number gets lower, and the tire gets wider, the outside edge of the tire may not clear the fender edge and the flange inside the fender. "Rolling" the fenders bends the flange out of the way and keeps it from cutting into the tire.
That said, the wheel will fit, as will almost any wheel with the right lug spacing. But no can say for sure that the tires will fit until they know the size and brand of tire, what type of suspension you will use, how much lower the ride height is, whether or not your fenders will be rolled, and if you have adjusted rear camber. Using narrower tires, with a more conservative fit, not all of these will be critical.
Now everyone please read the site rules on posting "hearsay."
wret said:Now everyone please read the site rules on posting "hearsay."
