16g turbo fuel setup
Boost controller and keep it at 16psi or lower. A 190, will be fine, injectors aren't needed till you hit 18lbs on your 16G. Hope that helps.
If he gets a 255, he might as well just get the quieter supra TT fuel pump. There is no need for the 255 or supra pump unless he is going 20lbs+ and upgrades from a 16G. The re-wire is a good idea.
550's and a re-wired 190 will be fine for the Sm 16g as stated above.. Wouldn't be a horrible idea to get little bigger injectors in case you upgrade ever..
