16g Oil Feed Fitting Size
TAL0NTSi
161
Dec 26, 2010
Westerville, Ohio
Quick question, does anyone know what size fitting I'll need for the turbo side of the oil feed line for a small 16g? I have a SS line that I used for my PTE turbo, but I'm sure the fitting is different. (oil is fed from the filter location) Thanks!
If I understood your question correctly I recently purchased that very fitting for my small 16g, it's the same as the stock 14b and it lists as MF650113 (replaces MF650013) EYEBOLT, T/C M12x23 and it obviously requires two 12mm crash washers MF660064 GASKET, T/C 12mm. This is the actual banjo bolt that goes on the turbo cartridge.
M12 x 1.25 thread.
