16g and 14b question
Focusonme13
60
Dec 18, 2003
Lyndhurst, New Jersey
i have a 14b with all the lines and stuff, if i buy a 16g with no lines, can i put the ones from the 14b to the 16g?, basically im looking to see if parts r interchangeable, please i need some help ASAP before i buy sumthing, thanx
yes it will work because when I did mine I had a 13b so the lines fit but the bolt holes were alil smaller so I had to drill them bigger but you shouldn't have that problem seeing you already had a 14b.
I've done 14b to 16G swaps, 16G to 14b swaps, and yes everything is fully 100% compatible. Hell, even alot of the internal parts for the 14b and 16G are the same. You shouldn't have any problems re-using your old lines. Just MAKE SURE that you remove your old oil drain pipe (the one that runs to the oil pan below) and also check the line running from the head for clogs. If they are clogged then it could interfere with proper oil flow, and you might end up with a nice brand new $600 16G paper weight.
