14B on a 2g how does my log look?
hellotbone
1,032
22
Apr 15, 2003
Time Short Long RPM Speed Timing Air tmp Air Flow TPS O2#1 O2 Trim O2 #1 O2 Trim 2
0.94 0 2 1740 9 19 52 4.6 95.48 0.9 0 0.78 0
1.87 0 2 2620 10 16 52 7.81 96.27 0.92 0 0.84 0
2.81 0 2 3524 12 9 54 19.08 97.05 0.96 0 0.88 0
3.75 0 2 5016 23 13 55 26.51 97.05 0.96 0 0.9 0
4.68 0 2 6400 30 19 55 28.29 97.05 0.98 0 0.92 0
5.62 0 2 4860 36 9 55 22.23 97.45 0.96 0 0.94 0
6.56 0 2 5140 47 11 55 25.36 97.45 0.96 0 0.94 0
7.49 0 2 5688 52 14 55 26.31 97.45 0.96 0 0.94 0
8.42 0 2 6180 56 16 55 27.65 97.45 0.96 0 0.96 0
9.36 0 2 6608 65 17 55 28.15 97.45 0.96 0 0.96 0
10.3 0 2 5280 68 7 55 22.63 97.45 0.94 0 0.96 0
11.23 0 2 5072 70 9 55 24.27 97.45 0.94 0 0.96 0
12.16 0 2 5272 76 11 55 24.9 97.45 0.94 0 0.96 0
13.1 0 2 5484 78 12 55 25.55 97.45 0.94 0 0.96 0
14.04 0 2 5680 81 14 55 25.92 97.45 0.94 0 0.96 0
14.97 0 2 5860 86 14 55 26.28 97.45 0.94 0 0.96 0
15.9 0 2 6028 88 15 55 26.87 78.59 0.94 0 0.96 0
not bad, could use some more timing though. Aim for about 18 degrees at 7K. Also, if you are on a pocketlooger, don't log so many meaningless things at once. keep it to rpm, timing, and maybe airflow if you really must know it.
Thanks I can't go any higher in RPM because its an auto :cry: thanks for the logging tips.
RPM Timing Air tmp TPS O2#1
1740 19 52 95.48 0.9
2620 16 52 96.27 0.92
3524 9 54 97.05 0.96
5016 13 55 97.05 0.96
6400 19 55 97.05 0.98
4860 9 55 97.45 0.96
5140 11 55 97.45 0.96
5688 14 55 97.45 0.96
6180 16 55 97.45 0.96
6608 17 55 97.45 0.96
5280 7 55 97.45 0.94
5072 9 55 97.45 0.94
5272 11 55 97.45 0.94
5484 12 55 97.45 0.94
5680 14 55 97.45 0.94
5860 14 55 97.45 0.94
6028 15 55 78.59 0.94
Looks like you could use a little more timing, either with better tuning or more injector.
Originally posted by hellotbone
OK how do I tune a 2g with no AFC?
You can't. What do your fuel trims look like? It may be possible you are overrunning your FPR and causing the injectors to lean out on the top end from flow decreasing. It's also possible that your stock SMIC is getting heat soaked.
