selmerguy
- 1,810
- 23
- Nov 14, 2004
Killeen,
Texas
My oil feed for my turbo is leaking pretty bad. I bought new brass washers for it and it still leaks. I have plenty of braided line and fittings so I would like to reroute the line from the oil pump housing and block off the stock oil feed from the side of the head. I searched on here and found out that the fitting for the turbo is like 7/16 inverted flare fitting. I cant find this fitting anywhere. I thought about tapping the hole to 1/4 npt and going from there. Is there any other option? Where can I get this fitting? I am running 4 an braided line.
