02 volt reader
Ghostriderdsm
88
Oct 22, 2008
lloydminster, SK, Canada
Well first off, hello i'm new to the board. I'm from ontario canada.
Now I'm wondering about the 02 voltage reading.
When i'm WOT i get around .094-.096, Idle i'm at like .02-.013, When i shift i'll go to -.043 to -.012. Is it the higher + side the richer you are what are levels that i should be looking to be around.
MODS ARE
1995 AWD TSI TALON
-stock MAF*not hacked*
-16G Big turbo*15 psi*
-450cc injectors-stock fuel rail
-190 walbro fuel pump
-1g throttle body-2g elbow
-1g CRUSHED BOV
-Fmic with hard piping*2.5"*
-3.5" full back with high flow cat.
-S-AFC apexi
-02 volt reader
-ALL DIY FOR 2g DONE
Your 02v should cycle from about .2 to .7 at idle if it does not do this and stays at a relatively low voltage you are either running lean at idle and have a vacuum leak somewhere or your O2 sensor is bad. Also I hope all your settings on the SAFC are at 0 for the Hi and Lo maps since you still have the stock injectors and MAS.
I would suggest resetting all of your settings to 0 across the board both Hi and Lo and see how that affects your O2v. Remember do not tune based on your O2v. It is not reliable for WOT tuning.
Do you have a logger?
Fill out your profile with your mods so that you don't have to post them every time.
I am not as familiar with 2g's as I am 1g's but I think most people just leave the 2nd O2 sensor plugged in and zip tie it up against the frame of the car. I think that keeps the ECU happy. 2g owners please back me up on this!?!? So, if you don't even have a sensor plugged in that would be a cause for your CEL on the 2nd O2 Sensor.
NO change.. I'm thinking maybe a 02 sensor on it's way out? Would that suggest why i'm running rich aswell?
Like were talking 280-300 miles to a tank IF that
If you set the settings to 0 and your O2v didn't start to cycle at idle then yes it's probably on its way out. But 280-300 to a tank isn't bad either. My 1g gets 19mpg that's about 200-220 miles to the tank. Then again the 2g has a larger tank.
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
