02 sensor simulator
cHy_boi-tUrBo
Nov 14, 2004
archbold, Ohio
hey i just got my 02 sensor simulator for www.02sensorsimulator.com and i install it arouind my secondary 02 sensor by slicing the wire and connect with the 02 simulator and i start it up and the check light engine is gone. but when i check my SAFC II is reading 100% throttle body and the car idle around 500rpm. at first i misplace the 2 black wires in the wrong place the black wires and put it back with the correct wire but that didn;t work and still the same problem. why the SAFC is reading 100% throttle body and why it idle low? was it the ECU was fried? or the 02 sensor simulator sucks? i;m going to put it back to normal and take the simulator out and see what happens? if that doesn;t work, is there ne clue why the car is acting like this? how can i get rid of the CED out and i just order 2 new 02 sensor just in case
My friend with an STi stacked 2 spark-plug non-foulers and put the rear 02 in the end of that contraption, and it keeps him from throwing a CEL. Apparently it lets just enough exhaust gas get to the sensor that it thinks there is a working cat in there. Thought I'd share.
