1996 A Pile AWD
parker4
56
22
May 14, 2009
Florissant, Colorado
After 22 years of ownership I decided a build thread for my car was in order. 1996 A Pile AWD.
In August of 2025 I took my dsm to the race track for the first time, a dream I had kept for a long time. Since then I have been blessed with having the time the car deserves to keep me not missing a local time attack series.
I will sprinkle some background of the car into the comments but this will start roughly 20 years after I purchased and started modifying the car.
In July of 2025 I moved from Seattle WA to Grand junction Co, about a 1100 mile move. I was fortunate to ship these shit boxes, when I was much younger I would road trip the Samurai 600-ish miles every other month.
Moved into a new house with a decent size shop! 850 sq ft!
I got the Talon on the trace track in August (25) it was 98-100 degrees and the car could only do 2.5 laps before Id come close to popping the head gasket. The car is flex fuel so it more than likely was on e-85. It had a MHI 16g with a 38mm tial recirc setup around 24 psi. I believe my PB was a high 67.xxx, for reference the track is .9 miles long. This is a go-kart track and is a time trail event (transponders are given out) 1 warm up lap, 4 hot laps and 1 cool down lap with 5 cars on track and no passing or point bye bye's.
I have a video on an on ramp when that setup was put together, if there is any interest ill find it and post it.
The next race (last of the season) was in October. Had a month to focus on some heat management for more lap time.
I decided I needed a hole in the hood above the turbo and started looking for the rare carbonetic backwards mounted hood vent. I found one for sale but unfortunately the seller would not separate it from the hood with me offering asking price for the hood. I got some 16g steel and let my imagination go. The power steering fluid had boiled over back in August as well. I built a fiberglass insulated heat box for the turbo hot side, ultimately I only used this once at the next race. Here is that.
October's race was very wet, I had dealt with a lot of under steer and would suddenly lose traction on all 4 tires; I had gone on old Falken 615's. When the track kinda dried out and I could push the engine a bit harder I was able to get a little over 3 laps in before the car would overheat with outside temps in the 70's (not good!). I believe I was able to get into the 66.xxx and left with a goal of getting into the 65.xxx's for the first race of the 26 season.
I had stuff to buy and I started with pulling the engine.
The first thing to show up was a chase bays 19 row oil cooler and sandwich plate. I built fiberglass surrounds for the opening in the bumper and surrounded the oil cooler. Used 7inch duct work from the Race Depot. I cut a large opening in the inner fender and added metal mess for protection. The intake also has a similar setup and I purchased plastic mesh grill material for these openings.
The next thing that showed up was an AFCO coolant radiator that tucks into the radiator support. Little more cooling capacity, further from the turbo hot parts, and a lot closer to the high pressure air from the bumper opening. Besides the weight moving further away from the front axle, all good things!
Anyway cut-up the core support and got to mounting. I lost my hood latch and the supporting structure so I used the top of the intercooler and the front crash bar to support a bracket I made for the front bumper top mounting flange. Really wanted this to be right so the bumper sits in the correct place. I then made side brackets that support but isolate the radiator from the electrical grounding circuit. An aluminum body containing water that is apart of a grounding circuit will oxidize at a very accelerated rate. I don't have any pictures but I made an airtight shroud that connects the intercooler to the radiator for opium air flow.
You can buy a fan shroud for this radiator but I couldn't justify the market value for it, I think it was close to $300 so I made one. I have two of those big ole Misihimoto fans but unfortunately could only fit one so I added those rubber flappers that help when the air pressure from MPH is greater than what the fan produces (I would love a brush less fan). I also added some trim that keeps the mild steel shroud from rubbing in the aluminum radiator, also made the fan shroud air tight.
Painted the core support and purchased new headlights. With the bumper cover installed the top part of the shroud that seals the radiator to the intercooler can be seen. I was very happy with how the bumper sits and interacts with the body lines. With the fan on it holds a paper towel to the front mount.
Next thing was the front Quaife LSD which was a slap in affair, no trouble there. I didn't snap any photos of the actual diff but the washers you see when you pull out a front axle is a dead give away. Keep that in mind when buying second hand transmissions, I scored a Quaife LSD for my CSM when buying a trans for $200! I purchased a FP fork which was the missing link to my not so perfect clutch feel I grew to know while also putting the master cylinder adjustment with-in spec!!!
Next I upgraded the turbo wheels to a 9 blade exhaust and a billet compressor, again kind of a slap it together affair. I purchased a J-pipe as well which looked to be the best on the market regarding flow, all from Kinugawa and this was not a bolt on affair. First the 12mm bolt heads on the flange were to close to the charge pipe to confidently reach torque, an easy fix moving to Allen hardware. After installing the engine I modified a charge pipe feeding the intercooler to better fit the car and interact with the newly installed oil cooler. The J-pipe off the turbo went into la la land (finger for reference) so I cut it up and made it work my application.
The radiator install ment I needed to put in some hood pins, nothing of real signifigance. It is very nice having two places to reference the hood to the car over the single no adjustable hood latch.
For maybe 15 years I have wanted the vanity plate "A PILE" and FINALLY got it done.
Purchased new tires Flaken 660+'s thanks to Eric Kutil and the GLTC grid.
The car had been remote tuned for the street with track driving in mind but I didnt like the overall expierence to go back with conserns found on the race track. I found a local guy that knows these cars and the ECM link computer so I sent the car to him. Its been a great relationship, he opens his schedule for me on race days waiting for logs and feed back. Support local.
Winter is basically over now and I am signed up for a test and tune session in March of 2026, offical races start in April.
March "test and tune" was very successful, it is not a timed event so I wasn't able to see improvements via time but the car was FLYING. The tuner told me he had kept some of the turbo on the sidelines as he didnt know how much or where I would want power, by the end of the day the poor little turbo was giving everything it had.
Ive been fighting for any over steer to help with rotation, the car loves its understeer. Also 2.5 of 4 hot laps in and the car is still overheating. Gonna focus on these two problems for the 1st race in April.
I made what I think is called a K bar? Basically it stiffens up the front sub-frame and was very very noticeable. Unfortunately over the 26' season this warps as I used incorrect material and it gets thrown out. It is on the list of things THIS winter to be rebuilt. I replace the front RTM sway bar with OEM, add camber on all four corners and re-align the car considerably changing toe angle.
At 330am I woke up screaming "EUREKA" and scared the shit out of my wife. I was dreaming of engineering a solution to keep the car cool for longer when I thought of the Subaru WRX. You could option it with a water sprayer for the radiator or intercooler (dont remember right now which it was) and I thought I could implement the same solution to my car. IAT's were not to much of a concern and I wanted to use this system as sparingly as possible with the greatest effect, so I mounted the atomizer in front of the radiator, not the intercooler. Just a simple garden sprayer hooked up to the windshield washer reservoir, distilled water is used. I wired the pump in the reservoir ultimately to be controlled through ECM Link so that it works autonomously however the controll parameters felt a bit archaic. I want the pump to turn on at say 210 and not turn off until 185. However the coolant parameter only looks at one coolant temp to turn on and off which uses the water up super fast. The software is awesome for a piggy back style ECU, it had enough parameteres so that the pump would never turn on while street driving. Ultimately I wired the pump to a switch that I control. I also take off the front license plate for that little bit more air flow and start dreaming of a front splitter / aero package (front splitter will push more air though the bumper opening).
April came around and I DESTROYED my pb 63.94 my goal was to get into the 65's and I skipped 65 AND 64!! About 50ish cars are at the track and I am placed in run group 1 (top 5 fastest cars) :dsm::rocks:. While I am the last and slowest in run group 1 a GL TrackMod Porsche is the next fastest car. Its a great team that owns a local machine shop and sponsors the event helping keep costs at a $150 entry fee. SUPER AFFORDABLE Ive spent $600 on a public track day!
The water sprayer works wonderfully well and I can now run all 4 hot laps.
The car loves the new alignment and front sway bar. The rear end is starting to rotate!! I can attack the curbing and the front end eats it up, that "K bar" is doing the lords work.
I purchased a phone mount and recorded a session chasing after the Porsche. Its a RAW video with no edits, keep in mind warm up lap and cooldown laps if you watch.
Over spun (my guess) the turbo and well it ugh yeah; as well as melted the exhaust valve seals :thumb:.
I cannot slow down so I pulled the trigger on a VS racing g30 660 ball bearing turbo. I wanted to get back on track ASAP and just about bought an Artec manifold as it was "in stock" but ultimately slowed down for better performance and ordered a JMF tubular manifold. I owe the guy, my recirculated setup was JMF and it survived hell on earth for many many years. I also purchased an EGT gauge becuase ill "page up for power" untill something breaks. Little shit was expensive, needed one with 0-5v output for data logging.
Lets all take a moment for Bobby at FIBA. I purchased a Quaife manual rack in a group buy as well as tried to buy this neglected EVO that has not moved in over 10 years. Unfortunately who ever was home wanted absolutely nothing to do with me, gotta try you know? haha.
My Wife is upset with how quickly money is leaving our bank account.
I took off the turbo and drained the oil, I did not find any glitter or metal. I slapped a small 16g into the exhaust housing (attached to fp manifold, welded flapper & tail recirculated) and turned to boost down as not to melt this turbo.
Bump steer has been an issue. Ive had these Megan tie-rods collecting dust for a few years, one set is 92-99 Honda Civic and another set is Honda s2000. After some lathe work I was able to combine the two resulting in a tie rod that mounts to the underside of the knuckle. I'm not able to adjust the tie rod in the perfect window as the tie rod mounting tab off the knuckle would need re-positioned its exactly where the tie rod wants to be elevation wise.
1 upper control arm bushing had evaporated. The only replacements I could find were in a complete urethane kit so I opted to make a bushing out of 3M window weld.
Now that car goes where I point it and the rear end is more playful I managed to beat my PB yet again 62.4. This was with a more restrictive turbo noticeably making 40whp less.
Manifold showed up as well as material for a ceramic insulated heat blanket. Mounted the EGT gauge but couldn't use the supplied sensor as they use some crazy design that doesn't interface with any normal EGT bung.
I change the oil after every race and when draining the oil after this race the magnetic oil plug was covered in metal as where the oil it self had hardly had any glitter in it.
The whole car had really taken a beating. Some how the oil pump casting regarding a seal surface took a shit. The pivot ball for the fork backed out (user error) causing the pressure plate to eat the new fork as well as stress the trust bearings. Obviously the bearings are shot and last but certainly not least, the passenger front wheel bearing took such a beating it broke in half. :ohdamn:
Parts are on order but its not looking great for the next race. I have missed a race or two due to travel I believe this happened after the August race.
I wanted (still do) to buy a bore gauge but couldn't justify the cost as a hobbyist. I took the crank in for polishing (Porsche team) and started buying ACL RACE bearings. After mixing and matching bearing shells 5 boxes ultimately were purchased. I aimed for a .0022 bearing clearance and will be using 15w-50 oil. This took me a long time to get done as motivation was waning and using plastigage meant when I wasn't happy with clearances I had to order a new set of bearings and wait for them in the mail.
This all sucked. My wife reminded me that I had been excited to race my car to see what breaks in a racing environment.
The season ended October 10th and the Talon did not make it to the last two events. I own a GR Corolla which I took to the events when the Talon was in various states of broken. I was able to get a 63.7 out of the car, for reference a 2024 WRX runs 67.xxx lap times. Thanks to the Corolla I was able to secure 2nd place at the end of the year in the HP2 class.
Some FIBA parts arrived, an alternator pulley and the newly released shifter bushings. I had to do a little custom work at the bottom of the shifter (new bushing was a little bit wider) with drilling a hole for a spring cotter pin. If you look closely you can see where the snap ring once lived.
I had been in contact for over 3 months with a local fabricator to build a down pipe who just kept putting me off. I reached out to another fabricator but they wouldn't take the project on in a timely manor. My wife had purchased me a tig welder many years ago and I hadn't done anything with it; I took this as a sign to learn tig and build my own down pipe. I practiced a bunch of butt welds and got to making the darn thing. Had some torch/argon issues (argon leak in the torch line I didnt understand in the moment) and Id to modify the torch to accept a larger than 10 size cup.
All caught up to current day shenanigans. I took the tires off the Talon wheels and donated them to the GR Corolla. Now the Talon is a bit stuck on the jack stands as the center bore is to small to fit GRC wheels on the DSM. A bit on the fence of what 2027 tire to use with the added power (have used 615k+, 660+ and cup 2's) as well as a bit worried with what may break.
I built a new (v3) intake partition out of ABS plastic to help save weight and do a better overall job at sealing. It has some shiny insulation crap on the engine side.
The exhaust manifold is fully installed, 13.5lbs of spring pressure is in the wastegate and hooked up to the -4 lines, the EGT cable was routed as well.
I realize I skipped over the modifications to the oil system I did when the engine was out.
1. The oil pressure relief port in the OFH was opened up (ported) so that the piston valve begins relieving oil pressure sooner in its stroke and has a larger opening to flow more oil at any time pressure is being relieved. I also shimmed the screw cap containing the spring that dictates the pistons movement so that less oil pressure is ultimately needed to move the piston in its operable stroke.
2. The oil pump gears where chamfered and shot peened.
3. The blanance shafts were elminated. I held on to these as long as possible but decided to delete them thinking of rotational mass. I used a GSC turned shaft to support the oil pump and blocked apporperate oil passages by rotating bearings.
4. I dissabled the thermostatic regulator in the sandwhich plate that feeds the oil cooler. Figure the oil can always run through the cooler, racing is the car's main prority so the cooler can always be on.
4. There has been a HLA regulator in the head as well as an oil pressure gauge.
-If/When time and money allow I will add an ACCUSUMP system as well as baffle the oil pan.
The car now is getting 3000gt brakes and a much needed detail.
  • Wanted 2g Wtb: oem 1995 awd front passenger axle with abs
    Looking for an oem (green) passenger axle for an awd with abs. Would love it to be install ready...
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
