- Thread starter
- #26
FIBA M - EC17PSE
Supporting Vendor
- 6,789
- 5,261
- Nov 1, 2008
Orlando,
Florida
since the last parts installed (new shocks) the cars driven really nicely and super happy now I have working shocks vs blown units! feels a lot better and handling is now back to a normal effect and not floating on air and very disconnected from the road
its a horrible feeling of floating.
I also changed some bits in the engine bay and you may notice it as it's a HUGE improvement now not only in looks but also color and leak free! Yes the DP had a nasty crack in it so I very much hated it. This gave me the perfect excuse to remove it all and remove that god-awful heat wrap, it was a nasty thing to look at, and had to go! This meant I could fix the crack with some welds, blast the manifold and DP and then VHT paint them and install all new gaskets to as I was sure they had broken also and I was NOT WRONG! The manifold gasket fell to bits taking it off the car so it is not sealing properly at all! grrrrr
Since this was done I decided to arrange a mini UK meet and we managed to get 4 DSM's together which for our Island is the BIGGEST UK meet ever to happen! was a great day with 2 of each generation turning up.
OH and a small minor mod was I ditch the front lower fog lights that never worked anyway and installed some LED DRL's. mostly because the headlights don't produce a lot of light and will help add some more in front of me. not original I know but Its what I had on the shelf so had to make do with that.
its a horrible feeling of floating.I also changed some bits in the engine bay and you may notice it as it's a HUGE improvement now not only in looks but also color and leak free! Yes the DP had a nasty crack in it so I very much hated it. This gave me the perfect excuse to remove it all and remove that god-awful heat wrap, it was a nasty thing to look at, and had to go! This meant I could fix the crack with some welds, blast the manifold and DP and then VHT paint them and install all new gaskets to as I was sure they had broken also and I was NOT WRONG! The manifold gasket fell to bits taking it off the car so it is not sealing properly at all! grrrrr
