1995 Eagle Talon N/T Vehicle Profile & Build Thread
Focker420's Talon N/T (w/turbo)
Eagle Talon N/T
Throttle body spacer,Msd ignition coil,short throw shifter and bushings. under drive pully. T3/T4 50.trim SPEC bov ,255 walbro,1:1 aero afpr 3/8 fuel line, custom fuel rail. 650 cc RC. adjustable cam gears AEM,
Mods-Engine
Crane turbo grind cams, 3 angle valve grind,p+p manifolds both intake and exhaust, and head is fully ported.2.2stroker, JE forged 8.6 comp, eagle H short rods howell. bored .040 over balanced engine,total seal rings. Arp head studs, mls HG.
Mods-EMS & Logging
MsNS, SAFC2, GAUGES-H2o temp, oil psi, boost, wideband o2.
lowered and new struts, stablalizer bars 1 front and 2 rear. Pollyurathane bushings for the contorl arms and strut mounts swaybar ect 17 inch rims and toyo proxy rubber.Slotted rotors.
Parts Wishlist
LSD....
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
2G DSM
Focker420
More in 2G DSM
Share this vehicle
