1991 Eagle Talon TSi AWD Vehicle Profile & Build Thread
Street Build
Tally the Talon
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
GT30 Variant
Drivetrain
AWD
Build Type
  1. Street
  2. Autocross
  3. Road Course
Fuel system:
AEM 400lph E-85 fuel pump
Fuel lab-6an tank to rail line kit
Fuel lab -6an rail to reg with Fuel lab regulator
FIC 1250 injectors
Exhaust:
3” Stainless steel hot pipe
3” Stainless steel STM down pipe
Custom 3” - 2.5” Stainless steel test pipe
2.5” HKS Catback
Intake:
3” intercooler piping hot and cold side
4” Intake to Turbo
Unknown 3.5” thick FMIC
Forge BOV
Tial 44mm wastegate
Cooling:
Unknown 2” aluminum radiator
Turbo:
Garrett 60-1 .70 a/r
Stainless oil feed from OFH
-10an vibrant oil drain
Mods-Engine
Cylinder head:
GSC STD Exhaust and Intake valves
Top line valve seals
BC Single spring titanium kit
BC 268/272 Camshafts
Ported and polished intake and exhaust ports
ARP Cam tower bolts
ARP Cam gear bolts
HKS Cam gears
Kiggly oil pressure regulator
Block:
Kiggly main girdle
K1 H beam rods
Weisco 86mm 8.3:1 pistons
Clevite tri metal main bearings
King xp rod bearings
ARP main bearing studs
ARP rod bolts
Full balance shaft delete
Mods-EMS & Logging
Ecmlink v3
Aem wideband
Speed density conversion
Gm iat sensor
Omni power 4bar map sensor
Ksport road course coilovers
Power stop Z23 drilled slotted rotors and pads front/back
FTP braided brake lines
Every bushing is energy suspension prothane
Moog front control arms
Moog tie rod ends
Moog sway links front and rear
Wedsport 17x9 forged wheels from Japan
225/40/17 lexsani summer tires(for now)
1G DSM
Joshuaivans
More in 1G DSM
Share this vehicle
