Activity Feed
Live updates
  • DP_52 replied to the thread ECMlink First post! ECU question.
    · 48 2,011
    I'm pretty sure the gauge the previous owner installed is junk... and is stuck at 30 something PSI and hasn't moved at allCurrently the car is running rich at idle around a 10.2 to 10.4 AFR on the AEM gauge I picked up and hooked it up to the...
  • Bebo____pr25 posted the classified ad Wanted Fp header in DSM Parts Classifieds.
    Good afternoon, everyone! I’m looking for an FP exhaust manifold/header for my 2G GSX. If anyone has one in good condition for a fair price, please let me know. Thanks!
  • kyler021 replied to the thread Resolved Catch Cans, Crankcase Pressure Questions.
    · 19 311
    Shoot sorry, don't know how I missed that in your first post.Also I'm noticing that you guys don't necessarily go out and look for a 3 or 4 port catch can. You guys add them on there yourselves, do you just drill, cut threads / weld for a...
  • jdxnc replied to the thread Resolved Catch Cans, Crankcase Pressure Questions.
    · 19 311
    Correct, as I stated in my previous post it's a -10an to pre-turbo.
  • dwb replied to the thread 2G Trans won’t go in 5th gear after clutch replacement.
    · 15 602
    That fork is definitely too far to the passenger side. Either the geometry is incorrect (fork bent or severely worn, trans not seated against the engine block, throw out bearing incorrect/broken), there's "pump-up" pressure from the slave, or...
  • 92PLazer replied to the thread 1G F4A33 Transmission Issues.
    · 9 430
    Wow, everyone. This has been a journey for me.To make a long story short, I dropped the pan and drained from torque converter as well. I let it drip for a few days, got about half a gallon out of the system. The gasket on the pan was, needless...
  • DumbtruckDSM replied to the thread 2G Trans won’t go in 5th gear after clutch replacement.
    · 15 602
    here’s an image of it. So it something worn in the trans? I only replaced the clutch and fly wheel I didn’t touch the fork and all the other stuff because I assumed since it worked before why not after the clutch and flywheel replacement?You must...
  • HyeToki replied to the thread 2G LC2 not reading in ECMLink.
    · 22 392
    The wiring is pretty much everywhere right now as seen on the picture and will be organized and tucked once the car is up and running.Everything is all temporary until I can get the car up and running.
  • sakroda replied to the thread 1G Looking for close-up pictures of the PCB underneath the knock sensor.
    · 7 248
    Hello again. I only had one ECU left from my late father’s old car. It had never been used, except that I had installed it once, and IC105 burned out. I had mentioned this to you before in connection with some other issues.Through the tests I...
  • Jacob5se replied to the thread Period correct 1998 Eclipse GSX.
    · 45 18,685
    I suck at regular posting, but here's a loooong overdue update on the car (there will be many photos as I wanted to do this as kind of a diary). I experienced a headgasket failure in April. Long story short car significantly overboosted (from...
    · 15 602
    Okay so I adjusted my clutch pedal, adjusted the rod, and bleed the clutch master cylinder and my car still won’t go in gear when it’s running. I did notice that when I tried to put it in gear the car started to roll forward and the rpm’s started...
  • dwb replied to the thread 2G LC2 not reading in ECMLink.
    · 22 392
    I haven't followed this thread but have you ruled out potential failed splices?There is a lot of debate between crimp vs solder wire connections. Both types, if done properly, work well. But I couldn't help but notice some of your splices (and...
    · 19 311
    Gotcha, and I see a fitting on the top there, is that for the vacuum I'm guessing? Asking because I was looking at a 4-port can and was wondering if I could use one of the ports at the top for vacuum and the other 2 for the actual PCV/oil.I...
  • Pjj replied to the thread One of One Eagle talon -Fittipaldi Prototype.
    · 445 78,979
    It’s here at the Shootout this weekend. 54k miles, has all the original parts at home. Looks to be in Ohio now, new owner is super nice. Said he’s been following it since 2004 and it super happy to have it in his possessionYou must be...
    · 22 392
    Thanks! will do that tonight!When i had the AEM Inifinity ECU, the front OEM o2 was removed and replaced with a Bosch O2 Sensor that was connected directly to the AEM ECU itself.When i removed the AEM, I also removed the Bosch O2 and added a...
    · 19 311
    The current setup goes to the rear of the car, as it's a dedicated drag car now.For the longest time it was a simple Greddy style can that I added AN fittings to. I also added an interior divider along with some SS wool to help seperate the...
  • tschuhly replied to the thread 2G Oil pressure sensor wiring.
    · 14 196
    What are the typical gauge sensors that are "logged" by the ECU from factory and which are simply from sensor to gauge?
  • curt-s replied to the thread 2G Oil pressure sensor wiring.
    · 14 196
    If two, same. Incorrect fuel pressure, while not providing an exact number, would at least present as an AFR inconsistency. Very "out of the ordinary" MAF compensation/VE requirements would also occur. Once you see that weirdness, one could swap...
    · 14 196
    No, that's correct, it should be reproducible depending on oil temperature and is entirely RPM dependent much like fuel pressure is intake pressure/vacuum dependent. However, it's much easier to maintain a constant oil pressure to give enough...
