Activity Feed
Live updates
  • GJP396 replied to the thread Resolved New 2G rear LSD CV axle option!.
    · 40 24,707
    Awesome to hear everything went together. Also nice to be able to help out on here, I'm pretty sure we would never have finished our car without all the information here......
  • 2GbTalonGuy replied to the thread What did you do to your DSM today?.
    · 12,117 839,234
    Went to a meet/cruise at the theater for the 25th anniversary showing of the fast and the furious and met a couple other DSM owners there.You must be registered to see element.You must be registered to see element.
  • SixBolt_16G replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,788 170,048
    They really are. I wanted a set for the Eclipse, but the 1g in a 2g setup makes that hard with the mismatvhed hoses and they dont make 1g hoses.
  • VBR_DSM replied to the thread Resolved New 2G rear LSD CV axle option!.
    · 40 24,707
    Good news guys, the RR cup went all the way into the diff without the snap ring. As suggested, I then applied a small amount of grease to the snap ring to center it in the groove, but it was still sliding down a bit. So I clocked the open end of...
  • b00zt3d spyd3r replied to the thread What did you do to your DSM today?.
    · 12,117 839,234
    Disassembled the valve train on my head and found what im sure is the reason for my lower compression on cylinder one. Piece of plastic was stuck between the valve and the valve seat causing it to not close all the way. Almost EVERY valve stem...
    · 1,788 170,048
    Due to @pauleyman pet peeve for kinked aftermarket coolant hoses this week, I could no longer see past the hose on the Prelude that i did earlier this year and didnt trim. Which was due to sheer laziness because i already filled it before i...
  • chrysler kid replied to the thread 2G 2G accessory belts misplaced / rubbing?.
    · 9 367
    Yeah the outer pulley is on backwardsTo correct it you would need to basically take off the alternator belt, then loosen the bolts on the water pump pulley, then loosen the steering pump to give that belt some slack, then fully remove the bolts...
  • Fomks replied to the thread 2G 2G accessory belts misplaced / rubbing?.
    · 9 367
    I took some more pics and I think you’re right, but if I flip the outer one, the inner one would still be rubbing, no? Or, are they both backwards? 🤔Part numbers are OK, the outer one is 980 instead of 985, but that still falls within the...
  • PLDSM replied to the thread 89 RAM 50 4g swap "Validation Plan".
    · 130 26,528
    Bed is on..... very very weird seing all this one matching color again. You must be registered to see element.
    · 9 367
    Yeah in your video the gap between the belts is much too large, the outer pulley is for sure on backwards. It could also be that the bolts are loose causing the inner pulley to be misaligned.It might also be the wrong belt on the steering...
    · 9 367
    Well damn, that would explain it! You’re sure? I heard a garage did the water pump replacement… thought it would be done well, guess that shows what I know. Is it hard to take care of this myself? For reference the hardest thing I did so far was...
    · 9 367
    Your water pump pulleys are installed backwards. Well atleast one of them isYou must be registered to see element.
  • chrysler kid replied to the thread 2G Fuel pressure fluctuation.
    · 62 2,192
    Like this one?You must be registered to see element.You can get a fuel pump assembly with a 3/8 barb for a neck fitting on RockAuto. If I ever broke the factory slip one I was just going to use a 3/8 barb into the sending unit. You can get...
  • GhostTypeP0300 replied to the thread 2G My scan tool and my DVOM disagree..
    · 12 753
    Everything tested fine at AutoZone, not sure why the flickering lights. I did upgrade the alternator output cable. I'm thinking maybe a loose connection were I bolted to the fuse. Not sure yet and also checked the alternator plug and it clicked...
  • dwdsm replied to the thread 2G Electric power steering.
    · 11 2,460
    Having chris do mine as well. What's the alternator requirement for this swap? Anyone still on stock 75amp? I have no HVAC among many other things deleted but still have a full stereo
  • Hello guys! I need some help finding the problem I got out of nowhere. Looking at the logs it seems when the ECU is going in open loop it cuts the injectors. I'm not sure if this is the problem but the car is hard to drive, engine is stopping...
  • steve replied to the thread 2G Fuel pressure fluctuation.
    · 62 2,192
    You mean here?You must be registered to see element.You fell out of closed loop about the same time your MAP sensor started acting up. Notice how it doesn't react to your changes in TPS afterword and the choppy O2. Perhaps some of this is...
  • CDgr97GSX replied to the thread 2G Fuel pressure fluctuation.
    · 62 2,192
    I posted two logs. In 02.02 at second 138.098 I have 2131 rpm and 6% throttle position and ECU is in open loop, second 138.164 rpm 2166 throttle it's still 6%, idle switch is off and ECU goes in closed loop and fuel flow goes down to 3.3cc/min...
  • MindBlowin03 replied to the thread 2G Fuel pressure fluctuation.
    · 62 2,192
    What are your opinions on the Radium dampener? I was debating on installing one(or two even) but haven't read much on their effectiveness.
  • So with the Electronic assist how does it feel now? I'm in group buy 2 and drove the car looped last night and yeah if the new manual rack is just as tough I hate it. No more arm out the window one hand cruising would have me just taking the BRZ...
