Activity Feed
Live updates
  • ItsTwan309 replied to the thread DSM Shootout 2026.
    · 41 2,121
    10 Days Ladies and Gents! Im ready to see some wild rides, scope some good used parts, and make memories with my daughter! See yall soon
  • heresjimmy42 posted a question on the classified ad Wanted 2g Oem turbo intake pipe.
    They had that piece of hose black taped over the tube with a clamp on it. That's what that white crud is I took it off to make sure it wasn't damaged and it doesn't seem to have any cracks or splitting
    I think I have one. Let me dig it out and I'll send a pic
  • dwdsm posted the classified ad For sale H&R Race springs in DSM Parts Classifieds.
    Gently used springs that I swapped out for coilovers as I wanted to actually raise the car a bit. (I'm getting old) Noting wrong with them except for a little overspray from painting the car.
  • Mahreeoh17 posted the classified ad Wanted 2g Oem turbo intake pipe in DSM Parts Classifieds.
    Looking for an OEM intake pipe for a 2G DSM. If anyone has one collecting dust please DM me. Payment ready to go. Thanks!
  • diambo4life replied to the thread Resolved New 2G rear LSD CV axle option!.
    · 40 24,708
    Axle should not just go in with a push. Needs a really firm hit to seat it in. That's how mine went in. Sometimes you may need to turn it a small turn at a time and repeat. I always use the technique of using a little grease on the circlip to...
  • VBR_DSM replied to the thread Resolved New 2G rear LSD CV axle option!.
    · 40 24,708
    I plan to work on it this weekend guys. I will try it without the snap ring and move to the grease trick from there.@GJP396 & @diambo4life - did your axles go into the diff with a simple push by hand or did you hit it in with a dead blow hammer?
  • athlete3344 replied to the thread Long awaited decade long project.
    · 35 4,242
    I can't be the only one that deeply inhales the smell of new parts, right?
  • pottersgst replied to the thread What did you do to your DSM today?.
    · 12,118 839,541
    Clutch install complete Fluids show no signs of leaking. 150 miles complete on break in of new clutch. Nice friendly driving for food shopping and some home supplies from Lowes. Few thumbs ups and one kid recording as I passed him. Missed driving...
  • Vladimir replied to the thread Pet peeve.
    · 18 897
    Short hose syndrome....they go to the meets to measure who got the longest hose. Heard ladies love a man with a slightly kinked hose...
  • miliman13 replied to the thread Long awaited decade long project.
    · 35 4,242
    Who doesn’t love a box 📦 full of new parts :)
  • miliman13 replied to the thread Resolved New 2G rear LSD CV axle option!.
    · 40 24,708
    Yeah I really want some concrete reinforcement maybe more images because I thought this was a done deal buy 3x axels make 2x out of them.
  • pauleyman posted the thread Pet peeve in The Hangout.
    This doesn't really belong in any tech forum just a pet peeve. Just about every DSM pic I see, for sale, showing off, car show, whatever. Why, why, why do people install aftermarket radiator hoses right out of the package and put a big kink in...
  • 92AWDHX40 replied to the thread What did you do to your DSM today?.
    · 12,118 839,541
    Hooked up my heater core hoses, fixed my oil drain, found my front and rear strut bar, checked timing marks,, cleaned up a bit, preparing for shootut. Plan to fire her up and get some help and ideas for the fall and into next year.
    · 35 4,242
    Latest box of parts. Fuel components are gd expensive! Will be running new feed/return lines, installing bulk head fitting on fuel pump hanger, and swapping the siphon assist via this thread: You must be registered to see element.You must be...
  • athlete3344 replied to the thread TD05 20g WG actuator bracket help.
    · 18 752
    Thanks Justin, I appreciate the feedback. Ill probably go a couple steps at a time for this. The goal right now is to get the motor dropped in and running in the next month or so. Might try the actuator I have on hand to see what happens, then...
  • GIB replied to the thread 2G First Gear Pops Out.
    · 67 3,235
    This is helping. I just got back from a little drive and it didn't pop out of gear. It did grind a little in first on a couple of shifts. I will adjust a little more and see if it helps, and update again. (I did also try again manually shifting...
  • Justin DuBois replied to the thread TD05 20g WG actuator bracket help.
    · 18 752
    I use a stronger spring for my Bastard 20G. With a 15deg clip - the spike is managed, and it needs a stronger spring to get more than 18psi out of it.
  • Justin DuBois replied to the thread Street Build ITFLYS - 1Gina2G.
    · 1,737 230,317
    I did go with a billet internal WGA, so that I could increase the spring pressure. At Redline, the minimum boost I have is ~16-17 psi. I have not used an external myself.I’ll take a look at the thread.
  • UKNOWHO replied to the thread 1992 Plymouth Laser RS.
    · 16 1,763
    well well have too much fun then its back to working on me the post on friday was at local cruise night car ran great no issues with temp but noticed strong smell of coolant but no leaks or anything on the floorsaturday night take her out for a...
