Activity Feed
Live updates
  • TasosEclipse replied to the thread 2G Oil leak.
    · 80 2,697
    turbo oil pressure from the head and the drain is 14an
  • Anfurnyy replied to the thread 2G Oil leak.
    · 80 2,697
    Tale as old as time it seems lol happened to me too
  • dwb replied to the thread 2G Oil leak.
    · 80 2,697
    You beat me to it ROFL
    · 80 2,697
    How do the valve stems look when looking into the intake and exhaust ports? Burned oil built up on them or no?What turbo oil drain are you using and where is your feed from?
    · 80 2,697
    nothing on the inlet. on the crankcase i measured 0 bar on boost.
    · 80 2,697
    Do you see oil in the intake piping? During a boost leak test with your tester on the turbo inlet, does it leak boost into the crankcase?
    · 80 2,697
    The consumption of oil is big that’s why I changed the seals
  • James92 posted a reply to a question on the classified ad Wanted ISO Extreme Psi weighted shift knob.
    That’s actually a genius idea. I had one years ago and then I saw one on eBay about 6 months ago and can’t get it out of my head!
  • 1990TSIAWDTALON posted a question on the classified ad Wanted ISO Extreme Psi weighted shift knob.
    Best of luck. I made one out of a small trailer hitch ball. :cool:
  • miliman13 posted the thread Question tab in The Hangout.
    You must be registered to see element. Why is it there ?It automatically by default appears to make all questions in the newbie forum.It doesn’t make you choose which sub section your question belongs in, which is great 👍, but then why have...
  • miliman13 replied to the thread 2G Oil leak.
    · 80 2,697
    Had same issue long ago - I had to change valve seals 2x the first new set didn’t seal well enough bought a diff brand on 2nd run - I think blue ones, as if color matters from brown ones.Difference was barely noticeable except for once the...
    · 80 2,697
    Yes I haven’t done anything to valve cover.
    · 80 2,697
    Do you still have baffles inside the valve cover?
    · 80 2,697
    I have two change them both checked with pressure everything good . The oil consumption is 500ml to 300 kmh.
    · 80 2,697
    How about the pcv valve? Good working order and not clogged?
    · 80 2,697
    Free flow only one line to take it back and down
    · 80 2,697
    What is your crankcase breather attached to? Does it flow free?
  • steve replied to the thread 2G Crank no start.
    · 5 368
    If you have the cable you just need to go to ECMTuning's web site and download the client software. You must be registered to see element.The 2G DSMLink V2 would loose it's tune if the ECU lost battery voltage so you'll need to find an old log...
    · 80 2,697
    They weren’t covered in oil they were just black . I know thats why I wrote here to hear someone else if it ever happened to another one.
    · 80 2,697
    Black and covered in oil are kind of different things. And I get you changed the valve seals but obviously something is still happening.
