Activity Feed
Live updates
  • Mando Vee posted a reply to a question on the classified ad Wanted Looking for T25 replacement.
    Yes, could you please provide pics
  • Nii posted a reply to a question on the classified ad For sale 2 bare 7 bolt motors.
    here are the engine codes
    they do not have split thrust washers
  • 92AWDHX40 replied to the thread Norwalk or bust 2026..
    · 406 59,609
    Progress
  • 92AWDHX40 replied to the thread What did you do to your DSM today?.
    · 11,949 764,310
    Today I got a body harness and solved a light issue, head lights tapped into my gauge cluster to get the ic7 my blinkers next install harness. Then begin putting the interior togther and mount Haltech. and more wiring. She is becoming a...
  • pat white replied to the thread What did you do to your DSM today?.
    · 11,949 764,310
    New brakes and boost controller installed along with rear struts ...much improved handling now and at 15 psi a little more oomph :cool:You must be registered to see element.
  • TheDude236 posted the classified ad Wanted [WTB] Hyundai 4g63 inner valve cover bolts in DSM Parts Classifieds.
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover. I need the shouldered bolts, not the studs. I also already have o-rings for them so if yours dont have them then no worries.
  • Justin DuBois replied to the thread 2G SRS diagnostics today.
    · 10 542
    SRS diags found fault code 25 - Passenger Airbag squib connection fault.I disconnected the ground to the battery, waited 10-15min. Disconnected/Connected the red connector at the left corner behind the glove box (it looked fine) and then...
  • voodoogsx replied to the thread SoCal Tuning Shops/Repair Shops.
    · 97 46,234
    Rays Garage and Performance in Van Nuys. Seems like a good guy. Had a DSM in the lot and some other Mitsu's on the lift. Talked to Ray about the shop that used to be there(Chai's old shop) and talked about finding parts(and how hard they are to...
  • 97egl posted a reply to a question on the classified ad For sale 2 bare 7 bolt motors.
    Looking at the center bearings in the main girdles you can see they have integrated thrust washer as part of the bearings. So neither would be a split thrust block.
    gotcha, I'll take a look at the blocks and give you a holler
  • pauleyman posted a reply to a question on the classified ad For sale 2 bare 7 bolt motors.
    FYI the split point is 95-97 and then 98-99. If the bearings are still there split thrust is 99 99.
    I'm in Oklahoma City and I would need to ask the original owner but I think they are 97+ 2gb motors
  • Mikealj posted a reply to a question on the classified ad For sale 2 bare 7 bolt motors.
    where are you located, and do you know what year they came out of?
    they came out of 2g gst Spyders. I understand that they had 7bolts in the 1gbs. but these are 2g gst blocks. I'm not saying this in any rude way just answering your questions. sorry if it sounded rude.
    The way you stated that it sounds like you are assuming they are 2G because they are 7 bolt? The 92.5 thru 94 1G cars came with 7 bolts but they have mounting points for the 1G front motor mount that the 2g do not have and that's what I am needing.
    7 bolt they are 2g
  • Ludachris replied to the thread FIRST DSM STREET BUILD!!!.
    · 384 52,423
    That last photo made me smile.
  • ItsTwan309 replied to the thread What did you do to your DSM today?.
    · 11,949 764,310
    man I love this! I want to see some more y2k style cars
  • ItsTwan309 replied to the thread 1G No tune.
    · 2 216
    Post pics of what your talking about, what are the mods on the car? Looks built says nothing since everything is inside the block and under the vc. Im sure someone in here can help you and wish you luck
