Activity Feed
Live updates
  • dsmmario replied to the thread What did you do to your DSM today?.
    · 11,840 728,684
    After completing a used Ground Control coilover install, I daily drove my 1g all week. The 90 degree afternoons with no ac made me question that decision. The trimmed Eibach prokits I had in there were fine (available for sale in classifieds) but...
  • FIBA M - EC17PSE replied to the thread 1g pop up headlight motors and arm.
    · 3 139
    We reproduce the 1GA Adjuster rods which are part number MB606225You must be registered to see element.
  • Thank you. Not sure what you mean by regular frame options? If you need a regular frame then best to replace it with an OEM frame.
  • jesse12345 replied to the thread Built 420a Eclipse.
    · 14 392
    Breaking things down in sections will be a game changer for sure. I just need to really stick to the plan and not wander off.I agree with you 100 percent! That red is one of my favorite colors on these cars. I appreciate the compliments on...
  • evileye replied to the thread 2G DSM Tubular Front Subframes – Making a Comeback!.
    · 5 357
    These look so cool! Do you offer regular frame options too? Someone bottomed out my 99 GS and the frame is dented af 😭
  • RoadRunner2g replied to the thread Oil return line leaking.
    · 10 314
    Thank you, I tried putting some washers on while at work but I think they are a bit too small, they barely sealed all the way around the hole in the flange and they still ended up leaking. I definitely need to find some that are the right size
  • miliman13 replied to the thread Built 420a Eclipse.
    · 14 392
    This * I did everything before I got around to dealing with the same issues your showing.That R87 radiant fire 🔥 red - looks amazing 🤩 she gorgeous in and out.That was my original color many shades ago.I love seeing how you keep the 420s...
  • DSMPT replied to the thread 2G 2G GST smoking after 6 bolt swap.
    · 16 436
    Anyways you connected a oil feed line to a coolant line. I don't know how long exactly you ran the engine being like this and how much coolant got into the oil passage and vice versa, but I imagine that the oiling system got a lot of coolant, and...
  • pauleyman replied to the thread 2G 2G GST smoking after 6 bolt swap.
    · 16 436
    That still wouldn't put coolant in to the combustion chamber but it would certainly contaminate both cooling and oiling systems. Did you not notice those are coolant lines?Your brother is wrong. The line at the head is oil. Both lines at the...
  • S'tan replied to the thread 2G 2G GST smoking after 6 bolt swap.
    · 16 436
    I took off one of the plugs on the head, thinking it lead to an oil gallery (I was tired and didn't think about it as much as I should have). I connected that line to the oil filter housing. My brother later told me that the plug I removed on the...
  • theface replied to the thread 1g pop up headlight motors and arm.
    · 3 139
    napa canada doesn't list them ,tried with part number .They cant see usa or bring them in from there for some reason ,.thanks tho
  • 19Eclipse90 replied to the thread 1g pop up headlight motors and arm.
    · 3 139
    I don’t know if you have access to a NAPA in Canada, but they list the motors in their website. May be worth reaching out. Worst case, they give you an aftermarket part number you can search with as well.You must be registered to see element...
    · 16 436
    Backup, you hooked up what coolant and oil line? Even if you did no lines would feed coolant into the combustion chamber. Elaborate please.
  • can we still buy or find new pop up headlight motors and arms for the 1g talons , been looking haven't found anything maybe something crosses over or am i not looking in the right spots? need both sides and arms in Canada.
  • 92AWDHX40 replied to the thread What did you do to your DSM today?.
    · 11,840 728,684
    Installed my brembos again, tucked my harness out of sight except for about 3 wires. cleaned the glass,. installed my mount finally on transmission torque solution needed some help with the factory bracket. Made a new list of things for june.
    · 14 392
    This car is officially mine! That being said I'm trying my hardest to ignore the rot so I can continue to build the engine. I will not let my ocd get the best of me.My plans are to get it back up and running and see what it'll do on its current...
  • Hello, I was just wondering if anyone could provide some guidance to help me resolve an issue I'm having with my 97 GST.I recently did the 6 bolt swap on my engine, with a few upgrades along the way. I've rebuilt the engine before but this...
  • 1991dsm59 replied to the thread 1G 6 bolt Moroso Baffled Oil Pan clearance issues.
    · 13 666
    Not sure if the link will post here but I found another tube crossmember kitYou must be registered to see element.
  • Drewpy Dawg replied to the thread Oil return line leaking.
    · 10 314
    There's your problem!Use properly sized copper crush washers.
  • jersygsx posted the classified ad For sale 2g 2G DSM Link V3 in DSM Parts Classifieds.
    2G DSM Link V3 $600 + shipping and paypal fees* no cable included * cables are 75 on the ecmtuning websiteYou must be registered to see element.You must be registered to see element.You must be registered to see element.
