Activity Feed
Live updates
  • 1990TSIAWDTALON replied to the thread What did you do to your DSM today?.
    · 11,789 714,453
    Yep, the one we were fooling around with. I haven't driven it much with all the rain making the surface very compromising. :oops:
  • Badge023 replied to the thread What did you do to your DSM today?.
    · 11,789 714,453
    Cleaned up some 1g fog lamps.You must be registered to see element.
  • enriquez2000 replied to the thread What did you do to your DSM today?.
    · 11,789 714,453
    Got injectors back from FIC and had to play after redoing timing and putting injectors back inYou must be registered to see element.
    · 11,789 714,453
    Is this on the one I was working on the tune?
  • enriquez2000 replied to the thread 1G No start car issue.
    · 23 729
    We are fully alive now... Fuel Injector Clinic also fixed up my injectors and read to street tuneYou must be registered to see element.
  • 92AWDHX40 replied to the thread What did you do to your DSM today?.
    · 11,789 714,453
    Buttoned up under carriage,topped off tcase, got pics of my carbon hood.. should be here in a few weeks. Can't wait to rock this thing. Gonna take lots of pictures. And Ohio is where I will show it off..Definitely gives me more excitement to...
  • voodoogsx replied to the thread 2G '95 MPI/Fuel Pump Failure?.
    · 18 476
    I thought it almost sounded like a low battery, but resistance could be it. Definitely need to do more inspection before cranking again...
  • voodoogsx replied to the thread 2G 95 Eclipse GSX questions.
    · 36 1,369
    Out of curiosity, what was the reason for pulling the head? Most of what it looks like you've done could have been done with just the valve cover off. What issues were you trying to resolve? Was the car running? Were there any compression...
    · 11,789 714,453
    I filled up the rarely used AEM Water/Methanol tank on the car. I am having a bit of knock up top, even on E. Boost Juice at 49% Methanol was my goto for now. I'll back the timing down after this "test". I haven't used it in years. ✌️You must...
  • phant0mxx replied to the thread 2G 1995 Eclipse GST engine sputters when free revving.
    · 24 360
    I've tried 2 other MAFs, one spare one I had and one from a good known working car. Using the US spec ECU and watching the live data I don't see any erratic MAF related signals. TPS also outputs linear voltage.If I hold the pedal until it...
  • pauleyman replied to the thread 2G 1995 Eclipse GST engine sputters when free revving.
    · 24 360
    Hiw about this. Get the car somewhere dark and watch for acing issues. Yiu could have a crack on a coil tower and didnt spot it. Wires are almost certainly ruled out. I had a similar problem once and it was arcing at the spark plug boots but...
  • Ludachris replied to the thread NorCal DSM Pulse Check.
    · 28 1,444
    Any Norcal DSMers want to help volunteer at our pancreatic cancer awareness fundraiser car show at Red Hawk later this month? Better yet, anyone want to volunteer to help us park cars and get cars checked in? You must be registered to see...
  • FIBA M - EC17PSE replied to the thread 2G 2g 7bolt middle timing covers.
    · 2 109
    Got to be careful of printed ones as unless it is an industrial printer, most will leave lines in them and create cracks. The best way is to use a proper industrial printing machine or, as we have said, if NO ONE comes out with a quality one by...
  • flintoid replied to the thread 2G 1995 Eclipse GST engine sputters when free revving.
    · 24 360
    have you tried swapping the MAF? The throttle being unresponsive and sometimes killing it seems like it could be a bad MAF signal. Along those lines, have you checked the signal from the TPS? Is the voltage a linear increase or does it have...
    · 24 360
    I have swapped coils and measured the resistance of primary and secondary coils, all were within spec. By grounded properly you mean bolted to the intake manifold? If so yes. To me it sounds more like a "soft" injection cut rather than a "hard"...
  • steve replied to the thread 2G 1995 Eclipse GST engine sputters when free revving.
    · 24 360
    This indicates that the ECU was unable to lower the idle speed to it's programmed setting and has attempted to close the ISC 100%. You mentioned a bad ISC blowing the drivers in the MD305162 ECU. Have you measured the coil resistances of the...
    · 24 360
    How are your coils? have you swapped those out? Are they grounded properly?I'm hyper focused on ignition because I had this very same issue and it was plugs/wires for me. Free revving it would break up close to redline. Then under load...
    · 24 360
    Afaik, pinouts are identical and the car behaves exactly the same with both ECUs. My best guess is that outside the US OBD2 wasn't mandatory from 1996.Installed brand new BPR6ES plugs and gapped to 0.028". Wires are also brand new.The high...
  • shad0wsoda replied to the thread Denver Area Spring Meet.
    · 2 173
    You must be registered to see element. This is the next event happening in Denver. Location gps is 7346-7558 W Bowles Ave Littleton CO 80123 (Picnic Tables).
    · 24 360
    how new are your plugs and wires? how are the plugs gapped? Have you measured them?High rpm break up sure sounds like it's your plugs / ignition. Just because they were taken from a running car doesn't mean they'll work in yours. You...
