Activity Feed
Live updates
  • Nii replied to the thread ECMlink 1G MAP sensor reads positive.
    · 121 4,583
    Thank you I'll look into it; I'm working on the hot start issue currently for the 1g trying to figure out why she does not want to start again after shes run and warmed up. I have to wait an hour before she will want to start again. its not vapor...
  • pottersgst replied to the thread 2G Clutch master cylinder.
    · 31 6,743
    Couple days early how's the one year update looking? happen to need to change master as well, Luc happens to be only one in stock locally I can find in jersey at moment
  • SixBolt_16G replied to the thread 2G Dash Light LEDs.
    · 3 126
    This. The back of the guages have an orangish film. Lightly sand it off where the number are so the blue shows through.You must be registered to see element.Pic taken from this thread: You must be registered to see element.
  • kyler021 replied to the thread ForcedFour Time Capsule.
    · 37 2,708
    There's the quarter panel molding in my local junkyard. Door and fender moldings are either messed up or non-existent. That may be your best bet, or maybe hit up Miller Import Parts? I had a good experience buying a fuel tank from him. He has a...
  • We're on Boost replied to the thread ECMlink 1G MAP sensor reads positive.
    · 121 4,583
    Have a couple of thoughts about how to do this that would be worth checking into more if you ever wanted to go this way.1.) You could buy a You must be registered to see element. and bolt the FP30 housing to it. I think. It looks like you...
  • jamel16 replied to the thread Street Build Project 1g (NBA DSM).
    · 378 53,440
    Small update: Received my CanChecked md15 gauge today. So the plan is to keep my oem gauge cluster and have Haltech control the warning lights. The MD15 will monitor all the engine sensors. You must be registered to see element.
  • steve replied to the thread 1G 1GB Independent Fog Lamp Operation.
    · 5 204
    I can't quite read your notes but this was the very first mod I did to my car and all I did was ground pin 2 on the fog light relay.
    · 121 4,583
    Good! The worst thing would be if it was way out of balance, like due to a chip out of a blade edge or something like that.There is something really wrong with the You must be registered to see element.. If that page is even current and...
  • pauleyman replied to the thread 2G 95 Eclipse GSX questions.
    · 36 1,386
    Read the directions carefully. Those are torque to yield head bolts. The procedure is specific. I like to use an angle gauge. You should also run a clean out tap through the holes and blow them out. I use a bottoming tap or I make a clean out...
  • llxkevinxll replied to the thread 2G Dash Light LEDs.
    · 3 126
    I think it would be because the dash has an orangeish film layer that is changing the color? Blue+dull orange would make greenish.
  • TheRock1209 replied to the thread 2G Dash Light LEDs.
    · 3 126
    You must be registered to see element.Here’s the video
  • Hi everyone. I decided I wanted to upgrade my gauge + HVAC halogen running lights to LED. I got these blue LEDs I’ll attach as a photo. I installed it in both locations. For some reason, the dash gauges are a greenish look to them, compared to...
    · 121 4,583
    that's the plan I want to take her out Friday and Saturday to start getting some propper data so I can begin to dial her in. I'll get those min and max tables dialed down and continue from there. I think the housing is the fp30 but I'm not...
  • AgustinGSXTribute replied to the thread 2G 95 Eclipse GSX questions.
    · 36 1,386
    I honestly don't care as long as they're in good condition. Prefer stock
  • opn0 replied to the thread ForcedFour Time Capsule.
    · 37 2,708
    Yeah that makes perfect sense.It just sucks cuz like... I don't know where else to find the sidemolding. People rarely remove it, so I'm in a weird situation where there isn't a ton of aftermarket for it. Regardless, I'll figure it out...
  • Aug 28, 2026 at 7:00 AM → Aug 30, 2026 at 5:00 PM
  • GIB posted a reply to a question on the classified ad Wanted 2g Radiator Fan Plug From Harness.
    Nice! Thank you!
  • Detail posted a reply to a question on the classified ad Wanted 2g Radiator Fan Plug From Harness.
    Try ohm racing.
  • Simo_217 replied to the thread Haltech Retain original Tach functionality using Haltech.
    · 5 253
    I have the haltech elite 1500 on my 2g , i wired the speed sensor like original schematic, and i use the same wire connected to the dash in the ecu
  • llxkevinxll replied to the thread Haltech Retain original Tach functionality using Haltech.
    · 5 253
    I have a 2G and an Elite 1500. My tach did not work. It would jump around sometimes but mostly sit dead at 0. Their tach adapter product page explains why this happens with older, ignition system driven tachs. I don't have an S2, but I don't know...
