Activity Feed
Live updates
  • enriquez2000 replied to the thread 1G No start car issue.
    · 23 909
    You must be registered to see element.Solid mounts vibrated this loose.. use copious loctite with solid mounts!
  • import47 replied to the thread 2G 95 GSX barn find, first steps recommendations.
    · 55 4,038
    Jdc titanium has lugs that would work better that what you have alreadyFor removal try the tool or a torq40 and bang her in and remove or drill out the stud and replace the hub cause sitting for a while the bearing would have rusted to shit
  • Wilsonf4i replied to the thread 2G 2g ECU sensor ground pin 92 5v?.
    · 27 1,390
    THANK YOU for sharing this. I also selfishly neglected to share that this car has had an remtoe start installed from the original owner that I had got working for a period of time before. I wonder if this is faulty and I should rip it all out...
  • tschuhly replied to the thread 2G Brake lights won't work.
    · 9 469
    Ah! So with that unplugged the brake lights should work regularly? Or not at all?
  • waltah replied to the thread Resolved 1995 A/C problem question!.
    · 15 4,213
    A very helpful thread with my own A/C failure -- thanks to all! Misc. possibly useful comments:1. If you take down the controller (on the bottom of the blower) you can remove the four Philips head screws in the bottom plate, take off the...
  • Ekracz14 replied to the thread 2G Can't get Timing Belt to line up on my 2G Eclipse.
    · 7 1,092
    I try that before and it’s still marked the timing wrong every time I put it right where it’s supposed to go when I tight the belt, everything moves out of sync like the crankshaft mostly.Well, maybe that’s why every time tight the belt it goes...
  • kyler021 replied to the thread Street Build 98 GST Revival Street Build.
    · 103 9,886
    Well I don't really have a good update, but this past week has been non stop schoolwork and all that jazz. It's nearing finals week so I've been dealing with all that stuff.On Monday, I replaced the sway bar bushing. I had noticed there were...
  • Ludachris replied to the thread RIP Kyle Loftis.
    · 11 1,208
    The internal pain and loneliness can make life feel impossible to bear sometimes. Even for people who appear to be doing great. And you don't want your pain to cause pain for those close to you, or be a burden on them. You don't want to be a...
  • I feel like the boy who Cried Wolf with this boost control issue. I was doing some more troubleshooting and testing of the boost control to try and get back to where i was at on boost Ken said to set boost cut at like 44psi and pull the boost...
  • ChubMonsta replied to the thread DD Eclipse.
    · 10 1,246
    Wasnt able to get the materials need to custom fab some of the things i want so i decided to check my ECU instead. Overall in pretty good condition. I, very luckily, have a stock EPROM ECU so that gives little peace of mind but still might send...
    · 10 1,246
    Busy couple months. Lost brakes on road, replaced brake master cylinder and still had no fluid to the rears. During the downtime i moved main fuse box to Stock SMIC location and am currrently building a splash shield for that and a cold air box...
  • yeah it went pretty smooth. It did crack a little bit when he went near the cracked areas but it didnt explode or anything like that.
  • Ludachris replied to the thread quality tools.
    · 44 3,133
    Yeah, I moved all of my parts to either a cabinet (for parts that will definitely be used) or bins (for spares or future projects), and put the bins out in the shed 👀 Cleared up a lot of drawer space for tools only.
  • pma1123 replied to the thread RIP Kyle Loftis.
    · 11 1,208
    This just happened a few weeks ago in my circle of friends. From the front, this was the most happy, joking, full of life 41 y/o dude. But it was always 'whatcha working on' and never the right question. The worst way to learn how your...
  • Hey guys, Looking for a fully built AWD transmission for my 2G DSM GSX/TSi AWD project.Mainly interested in:ShepTrans TMZ Performance Jacks Transmissions TRE or any properly built W5M33 setupPreferred setup:Double synchro 1st-4th gears...
  • FIBA M - EC17PSE replied to the thread FIBA Motorsport product updates 1G - 2G - EVO.
    · 113 17,670
    A few updates on some of the development itemsCTS-V 2-piece rotors. These are now nearing their completed stages. The sample rotor is now cut out (reason for this was also to use it as a display piece) The bell itself is now printed and waiting...
    • isolator with optinal insert to stiffen or holes to allow some NVH dampening.jpg
  • pauleyman replied to the thread quality tools.
    · 44 3,133
    I haven't wanted to admit that to myself but that's a consideration. I have too many non tool drawers that I could move elsewhere. Drawers full of parts etc. I had thought this 56 would be good enough forever....maybe not.
    · 44 3,133
    I don't know if you need more compact socket trays as much as you need another drawer. I have all mine separated by drive size - 3/8" in one drawer, 1/2" in another and 1/4" in another. Though I probably have way fewer sockets/tools than others...
    · 27 1,390
    Do you happen to know if there's a harness drawing or schematic for this sensor ground wire I can start tracing? I'd find in the service manual probably? I looked around 4-20 but man these drawings are a little confusing I may have to study them...
  • steve replied to the thread 2G 2g ECU sensor ground pin 92 5v?.
    · 27 1,390
    If you are seeing seeing 5v on the Black wire for pin 92 even after you disconnect the Green/Yellow wire from pin 81 there is a problem external to the ECU. Only the ECU should be powering the sensor power line.
