Activity Feed
Live updates
  • tschuhly replied to the thread 2G Brake lights won't work.
    · 9 504
    After doing some more research, could it be the turn signal box? I got one off of a junk DSM and swapped it to no avail. But maybe that one is bad too?
  • FIBA M - EC17PSE replied to the thread -- STREET DRIVEN -- 1G FWD fuel tank options --.
    · 2 197
    How about restoring yours?If your internals are not corroded the rest can be restored nicely. The sending unit will need to be refurbished which is possible to do even on an old unit as long as it has a good starting point. Wiring can be fixed...
  • TC1995 replied to the thread 2G 95 GSX barn find, first steps recommendations.
    · 55 4,220
    So to get car idling I have a new jpipe on ordered with the proper vflange for my hks bov so I can put intake side of engine back together.You must be registered to see element. I'm assuming that after start up sensors are cycling and don't see...
  • steve replied to the thread 2G 2g ECU sensor ground pin 92 5v?.
    · 27 1,500
    There are more automotive multimeter videos on youtube than you can shake a stick at but some are painful to watch and you might not find one that looks like your meter.Here's how I measure current by first moving the meters probes to the...
  • LV-DSM replied to the thread 1990 Plymouth Laser.
    · 3 326
    Wow! Good looking car. Wish I was closer. These have some hard to find parts. However, it's automatic and not running so it's tough to appraise. I'd start at $5k and see where it goes. Maybe someone else will chime in with their opinion. Good...
  • FIBA M - EC17PSE replied to the thread 2G Electric power steering.
    · 10 1,937
    He is a great chap. Glad he can help so many out in the EPAS kits
  • My brake lights won't work and so far I've been able to find power from the battery to the brake light switch, when the other power output prong on the brake light switch plug is powered my brake lights turn on. All of my grounds at the rear...
  • Bedicine replied to the thread 2G Electric power steering.
    · 10 1,937
    Chris did my conversion recently. I haven’t powered it up yet but also did the manual rack conversion with it. I have a build series on social that I’ll have more on. Won’t link it here but Chris was great to deal with and very responsive. I...
  • KLuster replied to the thread 1990 Plymouth Laser.
    · 3 326
    I posted some pics. Thanks so much for your reply. I’ll place on ad on Craig’s list. I was just wondering how much I should ask to sell quickly?You must be registered to see element.You must be registered to see element.You must be...
    · 10 1,937
    We have a DSMer already doing EPAS conversions for people. He does them for our quickrack systems and outside of those been doing them for other people also and everyone loves them.Name is Chris Cole (I call him Mr Cole) and he is on our...
  • Wilsonf4i replied to the thread 2G 2g ECU sensor ground pin 92 5v?.
    · 27 1,500
    Thank you for taking the time to respond to me here Steve & i'm grateful to read your other messages on this subject in other posts I've read. So I guess I'm still confused about this. It should read 5V? You want me to measure how much current is...
  • cswindel replied to the thread What did you do to your DSM today?.
    · 11,897 750,306
    Is there a DSM club by chance?:cool::D
  • DSMPT replied to the thread Spyder ‘96 Spyder 2.4l Strange Noise.
    · 1 170
    Generally speaking, you should check for injectors, ISC, spark leak from spark plug wires or coils. If not, lifters, too. Those are the ones commonly making the clicking/tapping-ish sounds and would affect the engine stability when it goes bad.
  • 7 Bolt Front Cover Oil Pump, BS Delete Plug, Stub Shaft, Pick Up Tube $95 + shipping and paypal fees* oil pump gears are in great shape* if the buyer would like, I usually pack the gears with assembly lube before a fresh engine start up and I...
  • steve replied to the thread Resolved 1g Power antenna wiring diagram.
    · 3 307
    Not sure what you're trying to say here. My 91 came with a power antenna and it's documented in the 91 Eclipse Electrical FSM.It might be a Eclipse vs Talon issue as they were not optioned the same or priced the same.You must be registered to...
    · 27 1,500
    Remember that if there isn't any current flowing there can't be any voltage drop so what you read from a floating pin is whatever potential voltage is connected to the other side. In this case the other side is the +5v sensor power, so seeing +5...
  • Brad Bell replied to the thread 2G Electric power steering.
    · 10 1,937
    Would love to hear more about this project. I converted to a manual rack after my oem one starting leaking last year. Now I'm interested in an EPS system, I see Prius steering columns are favorable.
  • 19Eclipse90 replied to the thread PCV valve.
    · 14 685
    Any intake nipple. But I’d leave the brake booster line alone.
  • CKOPOCT replied to the thread PCV valve.
    · 14 685
  • Badge023 replied to the thread PCV valve.
    · 14 685
    That setup works on a race car, where you make a few passes break the engine down and put the car away. 19Eclipse90's advice is right, even that breather should be connected to the intake to pull the gases from the crankcase. If you plan to drive...
