2G Brake lights won't work
tschuhly
231
70
Nov 6, 2024
York, Pennsylvania
My brake lights won't work and so far I've been able to find power from the battery to the brake light switch, when the other power output prong on the brake light switch plug is powered my brake lights turn on. All of my grounds at the rear brake light plugs are good. And I've tried two new brake light switches plugged in, both have not fixed the issue.
After doing some more research, could it be the turn signal box? I got one off of a junk DSM and swapped it to no avail. But maybe that one is bad too?
Check if the brake pedal lever is no longer pushing the brake light switch in far enough due to a rubber pad on the brake pad lever that deteriorates and falls to pieces over time.
This actually ended up happening today as well but I am having the reverse issue. My lights won't come on at all.
They randomly started working and I have been breaking in my engine and they worked the whole time, so hopefully it's fixed.
I think it's one of those weird DSM things where as long as you're are trying to do something to fix the problem, the problem will go away. But as soon as you stop trying to fix it, it will come back LOL. It just wants some attention is all.
Sorry I gave the wrong link. The brake (stop) light switch goes both (via the green wire) to the brake light and the "turn signal and hazard flasher unit". So you said when you manually put +12V on that green wire the brake lights work?
Normally I would have said the brake light switch is defective or intermittent, but you said you replaced it.
A long shot but I suppose the "turn signal and hazard flasher unit" may have an intermittent short in it affecting the green wire (thus preventing stop lights working). You could try unplugging it to see effect.
No, I'm just suggesting unplugging it as a test to see it is causing your problem.
You said you are getting constant +12V on the brake switch's red-black wire? And if you short that wire to the brake switch's green wire (which is what the switch does) the brakes work every time?
That switch is actually 2 switches: brake (pins 1&2) and Cruise (pins 3&4). You don't somehow have the brakes connected to the Cruise part do you?
Oh I gotcha!
I don't think so because they were working for a a little bit.
Honestly they started working again without issue so I'm very confused but can't really test anything until they stop. That being said, I hope I never get the chance to test stuff haha!
Should the black and red wire be a constant? Do you know the pin configuration by chance? My brake lights aren't working and I have tried everything. I'm almost to the point to try another new switch. My current issue is that when I press the brake, the black and red wire goes from 0 volts to about 7 volts. The green wire never changes from 0 volts with brake up or down. Any thoughts?
The brake (stop) light switch's black-red wire goes to the battery through a 15A fuse in the engine fusebox (labeled "Stop Lamp" on cover - top row, 10th fuse from right). So it should be constant +12v if the fuse is good. Check it. The switch connects this black-red to the green which provides power to the brake lights (and some other stuff).
Since you say it starts at 0v, the fuse probably is blown.
{When you press the brake, it may be going to 7v because the fuse is blown and either (1) other circuitry on that wire is providing that "back" voltage and/or (2) the brake switch is faulty causing a short/open}.
However first try unplugging the brake switch connector and through a spare good 15A fuse (or temporarily remove and use the 15A "Stop Lamp" fuse if it's tested good) apply +12v to the green wire pin to see if the brake lights go on (to eliminate that possibility). If they work, then replace that "stop lamp" fuse to see effect. If still not working (and fuse may blow again), replace the brake switch.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
