Activity Feed
Live updates
  • Bedicine replied to the thread Is Carbonetics still operating?.
    · 9 906
    I’ve been trying for over two weeks now to reach them anyway possible. Also trying a chargeback at this point, was hoping it didn’t come to this considering I’ve supported them and bought a lot even when people bad mouthed them
  • TheDude236 replied to the thread 1997 Eclipse GSX.
    · 5 582
    I've got a feeling this thing was optioned with every high level option possible. Its got the garage control driver side visor, and an LSD alongside stuff like the sunroof, cruise, auto trans, electric driver seat adjustments, and A/C. I wonder...
  • FIBA M - EC17PSE replied to the thread 99 GSX Rebirth/Clean-Up/Build.
    · 989 209,659
    They look like Tioby ones from etsy You must be registered to see element.
  • TheDude236 posted the classified ad For sale 2g 1996 Eagle Talon Base in DSM Vehicle Classifieds.
    Up for sale is a 1996 Eagle Talon with a 5 speed and about 183,000 miles. Its an RS / Base spec Talon, but has working AC with a grey cloth interior. This car has 0 rust, it has a clean title, the interior is complete, and each cylinder had about...
  • We're on Boost replied to the thread Are there Clutch Pedal Rebuild kits?.
    · 23 1,370
    If your 15mm is the amount of slave rod travel you are getting, well, that's 0.590 inches, and that's between 9/16" and 5/8" You must be registered to see element. (that's an interesting thread BTW) when I had a heavy single disc clutch (ACT...
  • TheDude236 replied to the thread 1996 Eagle Talon Base.
    · 18 2,033
    Collected all the parts I have for this thing together, ready to go to their future home alongside the car. Well, everything mechanical at least. Theres much more still sitting in the car.Its really a bummer that this car hasn't sold yet. I was...
  • dwdsm replied to the thread 99 GSX Rebirth/Clean-Up/Build.
    · 989 209,659
    Oh man where did you find those? I just finished restoring/painting and assembling mine. Now it's find mint parts to keep upgrading.
  • Up for sale is a used 1G turbo engine control harness from a 1991 automatic, with ABS. It is used but complete.You must be registered to see element.You must be registered to see element.Repairs were made at the knock sensor connector, engine...
  • lglracer replied to the thread Mitsubishi Day at the New Folsom,CA Mitsubishi.
    · 3 204
    It was a great day! Lots of mitsubishis! You must be registered to see element.You must be registered to see element.You must be registered to see element.You must be registered to see element.
  • Mahreeoh17 replied to the thread 1999 GS-T Restoration Build.
    · 50 5,763
    Small thing. Wired up some slim Spal fans to a 1G rad, getting it ready for install. I used the pigtails from the stock fans and wired them in accordingly, and had my fab guy move the bottom posts to align correctly with the 2G chassis.
  • bettfootball replied to the thread 99 GSX Rebirth/Clean-Up/Build.
    · 989 209,659
    When I get it out next I will remember to get some for you!
  • Detail replied to the thread My other daily driver!.
    · 68 5,698
    Came across someone selling a car that had the extremely hard to find dc sport’s front strut bar on fb. Made him an offer months ago and he finally changed his mind. The boosted fab one is definitely a good copy!You must be registered to see...
  • tschuhly replied to the thread ECMlink Help with idle issue.
    · 7 480
    I found this on the ECMTuning website: You must be registered to see element.I also went into the direct access tab and reverted everything to stock settings.Do I need to flip my CAS on the engine since I am using an EPROM ECU that seems to...
  • steve replied to the thread Project: EFI SWAP What do I need to make it work?.
    · 82 5,111
    We all here know that ECMLink isn't garbage so it would seem that other things might be.You have come a log way doing something nobody else has tried and pretty far from a normal DSM. I know it's frustrating but pioneers often take a few arrows...
  • DogWhistle replied to the thread 2G F11 fuse keeps popping.
    · 3 309
    First verify that one (or both?) are the cause of the circuit popping by disconnecting them both, and then reconnecting one at a time to check for the short.You may have to cycle the power lock a couple times and open and shut the door a couple...
  • cswindel replied to the thread 1998 Mitsubishi Eclipse GSX.
    · 83 14,662
    And we are back on the road again! MO to CAYou must be registered to see element.
  • Lonestardsm posted a question on the classified ad Wanted black 2gb eclipse driver side main side skirt.
    It’s a long piece! You’re willing to pay shipping?
  • Turbski91 replied to the thread Old Man Tan.
    · 40 3,785
    Thank you! It really cleaned up nicely!
  • dwb replied to the thread Are there Clutch Pedal Rebuild kits?.
    · 23 1,370
    Either you still have air in the hydraulics or something is amiss inside the bell housing (fw step, throwout bearing, fork, pivot ball, or clutch falling apart). Do you ever notice a rattle sound coming from the clutch?
  • steve replied to the thread ECMlink Help with idle issue.
    · 7 480
    Before you do read up on how to get things back to stock because it's not as easy as it should be.
