YAY!! Another one of these threads
TJCTalon
953
98
Aug 20, 2009
Nebraska
Yep, this is yet another no start dsm thread. Please help out me and my buddy.
So my friend just bought a 99 gst with a 6 bolt swap. The swap was done by a 5 year old. Shit isnt right with it. Its a complete mess. On to the story... So one day my buddy went to start his car, and the pedal went to the floor. So I figured it was the slave, we replaced it and bleed it correctly. We got pressure back in the pedal, but it still wouldnt start. This is what we have checked so far:
We have spark
Fuel pressure
Injectors are firing
Timing is spot on
We changed spark plugs and the old plugs were fauled horribly. We put new ones in and it still wouldnt start. When we took the brand new ones out 3 out of the 4 were covered in oil. Figured shit, the piston rings are done. We do a compression test and here are the results
1: 50
2: 0
3: 110
4: 145
Wouldnt it still start with the compression on the two cylinders bad??
Why was it running fine before the slave went out? With no signs of rough idle or anything?
Help us out guys, thanks a ton.
You answered your own question. The engine has very low compression on two cylinders. Something is mechanically wrong, whether its valves, rings, headgasket, pistons, something is ####ed and it has to come apart.
Uh, compression on THREE cylinders is bad (below service limit). You're trying to start the car on 1 good cylinder. Regarding the timing - moons aligned?
Do a leak down test to locate the actual issue. It could just be that the valves aren't seating properly for all you know.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
