wut do u think about my setup
Stizzyflip611
85
Nov 21, 2003
Howell, New Jersey
hi guys, i plan to make my car fast street drivin car as most dsmers do. i just wanted to know if i am going in the right path. ive researched alot and this is wut i have done to the car and wut i still want to do, tell me wut u think:
installed in car: cruise control elim throttle cables, turbo back 3", shifter cable bushings and shifter plate bushings, walbro 255, new oem filter, -6 inlet and outlet fittings from fuel rail with an aero AFPR, kyb agx adjustable struts, eibach prokit springs.
wut i have ordered but not installed yet: ss exhaust mani studs, 7cm gasket, new mani to turbo bolts, new exhaust mani gasket,
wut im about to order and install: SBR cast manifold, evo3 16g w/ 34mm flapper and port job, dejon tool hard intake pipe, 3"GM MAFS and MAF translator, new fresh 1g bov, upper and lower intercooler piping, and a manuel boost controller.
i am still runnin stock 450cc injectors, and a new fresh oem clutch. i know i will have to be easy on the clutch but wut do u think about my setup?? will it be a good street/track car, wut 1/4 mile numbers to expect?? do u have any suggestions about wut ELSE i will need??
i was also thinkin about getting dsmlink on my palm pilot too :p
thanks for the space and your suggestions
Looks like you have it all dialed in, you've taken care of your fuel supply, all your gonna need are bigger injectors like 650's, and definenetly an afc and I assume you have a logger. You should be set.. whats wrong with your stock bov? you say you wanna buy a fresh one? why? just crush the one you have now and it would hold boost fine, and your definently going to need a fmic the side mount gets heat soaked easily, and I hope your OEM clutch lasts you well. I'd rec. a 2100/2600 but these are all my opinions any one else have other suggestions?
