GUY
- 86
- 1
- Mar 27, 2005
Springfield,
Missouri
hey, well after a few months of of tyrin to do this i am now out of ideas. Heres the problem, I have a 90 AWD talon. The SOB acts like its getting bad fuel cut all the time but everything on the car is stock. i cant get the car to go past 4000 RPM without a bad fuel cut feel. those of you who had bad fuel cut knows what it feels like. I have heard people say its a boost leak but how can a boost leak hit that hard and not make me get past 4000? So i have not given it a boost leak test yet. I know it has a bad fuel sending unit & a bad knock sensor but that should'nt be it? This is what i have replaced, new ECU, new plugs, plug wires, coil pack(used), all new fuel injectors, fuel pump, & i replaced the whole engine harness. i think that is it. if you guys have any ideas let me know asap! thanks, steve.
. Push 20 psi in the intake tract and if it holds around 30 seconds your good to go. If it doesn't, get some soapy water and start spraying your pipes. It has to be a boost leak. If it isn't a boost leak, its a bad MAF.
