wrong spark wire order, mess up the spark plugs?
DSMnOOb00
903
4
Apr 29, 2006
FRESNO, California
My car is miss firing... I found that I had the spark plug cables in the wrong order... would that mess up the spark plugs causing me to get new ones? I was running accel wires with NGK BPR7es plugs... gapped at .28... what cha guys think?
Cyl 1 & 4 fire at the same time. Cyl 2 & 3 fire at the same time. There's 2 coil packs. If 1 & 4 are on one coil pack and 2 & 3 are on the other and the car doesn't run, swap 2 & 3 with 4 & 1 on the coil packs. It's really that simple.
Wires and plug gap seems fine so long as the wires aren't old as dirt. Any reason you're running 7's and not 6's?
