Wiseco piston qustion
Bmxr152
579
May 27, 2006
Gardnerville, Nevada
I was wondering if you had to use those clips for the wrispins or if you only had to use those if you didnt get your pistons pressed. Thanks josh
The piston is designed for a floating pin, you can't press it onto the rod. What connecting rods are you using?
