Wiseco 9:0:1 Compression Question?
qwerty5678
Mar 16, 2005
Rotterdam, Europe
Hi,
I bought Wiseco Pistons 9:0:1 compression for my 2G 4g63T
Can someone tell me what is the different between the higher and lower compression than stock pistons. And which compression will be better to make a max. 300WHP??
thank you!
Ron
The Netherlands
www.steenhoek.tk
dude, if you only wanna make 300hp, you can stick with the stock bottem end. you can safely make 400 hp with the stock bottem end, and a lil over 500hp with really good tuning. and the diffrence between stock compression, and 9:1's?........thats about it, nothing. ive talked with numerouse dsmers, and they all said that they couldnt tell the diffrence between the stock compression, and the 9:1's. you best bet is to do all the supporing mods, and get a nice 50trim, or 20g or somthin. those are 350-400hp turbos, they are stock bottem end friendly, as long as u have good tuning. hope this helped man. :thumb:
Well i have about 500 miles on my motor now and i went with the 9:1's. I have to say that there is a small difference on the lowend, it feels a little more responsive. For a street car and your goals in mine i would definetly go with the 9:1's, and plus if you ever decide to go with a bigger turbo you should be able to spool it up a little quicker.
u wont run 400 hp on a 7 bolt stock bottom end for 2 long itll walk on ya
He's right. I only got 2.5 hard years of driving and 250 passes at the track on mine. :sneaky:
Eventually it poped the HG not really crnakwalk though it was out of spec...
So 400hp on a stock 7-bolt is the recipe for crankwalk, huh? I'd say that's an assumption and should not be taken as fact. We have a few Wisemen that would argue with your statement and they have firsthand experience with running 7-bolts.
This is how misinformation is spread folks.
all you guys were right. i think we should call this the crank walk stereo-type. i also have made over 400hp on my 7 bolt. the only reason i got a 6 bolt is because i got it for free. otherwise id have a 650hp 7bolt.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
