Wiring Up the Omega Turbo Timer 2???
Anarchology
72
Oct 4, 2008
Chitown, Illinois
Yes, I have the VFAQ tutorials, but they are little but helpful for wiring up a turbo timer to a 1G. The Omega Turbo Timer is a very basic and inexpensive timer sold in the Vendor's Section on this forum.
It does not come with the easy plug-n-play wiring harness, so I'm looking for the proper pin numbers for the wires I need to tap off the ECU and under the wheel. I already printed out the ECU pin numbers off of VFAQ, so I will have them right next to me.
Here are the wires noted off of the one-page install guide that came with the Omega 2:
- RED to Battery (fused)
- BLACK to Ground
- BLUE to Ignition #1 Wire
- YELLOW to Ignition #2 Wire
- ORANGE engine detect wire to Output of Alernator
- BLUE/WHITE to parking brake
- VIOLET to positive Brake
Other than the positive and ground, I need a little help finding the other wire taps.
Use, any guide found on the internet. You have the wire colors from the turbo timer, and where they go to. Just follow a regular guide, and splice the wiring on the car. Btw, you dont need to splice the ECU, you just need to go under your steering wheel, pull the harness and splice it.
