Wiring a Autometer Tach
did you loose your instructions or something? :D
you should have 3 wires, a black a red and another onother one
red goes to a 12V source such at the blue power wire to your HU
black goes to a good ground (I bolted mine to the firewall)
the other wires runs to the RPM wire that runs to the ECU. On mine it's a solid green wire, but i'm not sure what it is on your 2nd gen.
hey thank you for the info. I never had the instructions but there are 4 wires. i know that the red is hot, black is ground, green goes to the signal, and white goes to the lights. :dsm: JoBoy
if you no that .. then why are you asking the question ? do you not no were
to get the signal from ? if so - its pin 58
http://vfaq.com/mods/ecu-harness-2G.html
