Wire short issue please help.
Dumond123
Aug 22, 2011
ny, New York
So i recently hooked my halos on my projector headlights to a power switch inside my car, i grounded both lights on a bolt on the fend and ran both to 1 power wire which i fed through my fender and under my dash (should of went through firewall but didn't) :ohdamn: They worked fine for a couple days until recently when i shut my door and smoke started rolling out of my fender/hood, im assuming the door cut into the wire and shorted out. After removing all the wires and grounds for the halos i now have no dash lights no headlights no tailights no high beams and no gauge pod lights. The blinkers and brake lights work fine, i took it to my local shop and they checked everything possible all fuses, relays, grounds are all fine, sometimes my headlights will pop on without turning the switch or key in the ignition, same with the left parking light, they will just come on and not turn off. Also when i try to roll my windows up or down it makes a loud buzzing noise under my dash so i checked it out and i can feel a relay vibrating and buzzing like crazy i swaped them and nothing changed. Really dont know what to do here any help would be greatly appreciated. :confused: Car is a 1995 eagle talon tsi.
What was the resolution? Someone else may eventually have the same problem and you finding the problem and fixing it not only helps you but the other guy / gal who hits the search button and finds this thread.
